Raised Arm..BumpSteer
Discussion in 'The Garage' started by MITCH_89', Mar 27, 2003.
  1. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    With A total of a 4 inch lift (3" springs, 1" zero rates), my raised steering arm makes the draglink cause bumpsteer..so I put the factory arm back on. This causes quite the droop. I know there is supposed to be a slight drop from the pitman arm to the steeing arm. Is there a spacer I can use with less lift than the raised arm?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can get a drop pitman arm. I think most of them are 2 - 2.5"
