Raised steering arm, drop drag link, 8 lug conversion
Discussion in 'General Parts for Sale' started by fad2blk99, Sep 3, 2004.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    The steering arm and drag link are both listed on ebay:
    drag link
    steering arm
    Place your bids for these on ebay or make me an offer now (NOTE: out of respect for other bidders, I will not pull an item off the auction once some one has bid on it).
    I also have a 10b 8 lug conversion for sale (NOT YET LISTED ON EBAY)... $40 plus S/H.
    Now that I have my d60 I have no use for this stuff anymore /forums/images/graemlins/thumb.gif
  2. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Re: Raised steering arm, drop drag link, 8 lig conversion
    interested in 10bolt 8 lug conversion....what all does it include?
  3. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    It includes the D44 3/4 ton backing plates and rotors (w/ studs) and for an extra $5 I'll throw in the barely used 3/4 ton (2 5/8" piston) brake calipers...
    And just in case you didn't already know...rotors and backing plates are all you need for an 8 lug conversion on a 10b (or 6-lug D44), everything else from the knuckle out is the same... /forums/images/graemlins/thumb.gif
  4. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    I thought the hubs too /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  5. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Are you referring to the lockouts or the rotor and hub assembly (held together by the wheel studs)?
    The lockouts are not included (they are no good). Your existing lockouts are the same anyway. All that is needed to convert a 10b to 8-lug are the backing plates and hub/rotor assembly. Your spindles, wheel bearings, stub shafts and lockouts are all the same as a ½ ton and ¾ ton D44. There are two different size brake calipers but the difference is in the piston diameter. They are interchangeable. I’m offering the larger 2 5/8” calipers.
    The backing plates and the hub (inner portion of the hub/rotor assembly) are the most expensive and hardest to come by. The brake calipers and bare rotors (no hub) can all be had for around $20 apiece new (calipers would be newly rebuilt units). There is about a $15 core on each of the brake calipers if you don’t have old ones to turn in.
  6. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    If smprider is no longer interested, I am interested in the 8 lug conversion. Got any pics?
    Thanks,
    Ray
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    You wouldn't by any chance have six lug spindles and hubs?
  8. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    Ok as long as it's everything I need I'll take it /forums/images/graemlins/thumb.gif brake calipers too /forums/images/graemlins/thumb.gif
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    put me next if for some reason he doesnt get it. /forums/images/graemlins/thumb.gif
  10. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    I threw the hubs away a long time ago, but I do have spindles... $15 + shipping... you'd probably be better off getting them from a junkyard though. All straight axle Chevy 1/2 tons should be the same. /forums/images/graemlins/waytogo.gif
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    so what all will I need to convert to 8 lug??
  12. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Hub/rotor assmebly (minus the lockouts) and backing plates.
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    so do you still have all this??
  14. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    the 8-lug conversion is sold...
    However, the drag link and steering arm are still up for bid on ebay. Currnet bids as of right now are around $30 apeice.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    crap, ill have to keep looking.
