raising the transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sapper, Aug 29, 2001.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Does anybody know how you can get a 241 above the bottom of the frame rails?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    well, you would have to disconnect the crossmember from the tranny mount and slide it in at an angle from above then reconnect everything.
    Why are you asking?
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If you do that you driveshaft angles will be way off, and you will never get rid of vibration problems. Best thing to do is build a new crossmember that runs real close to the transfer case, and build a really strong skid plate. Make the skid plate out of 1/4" thick steel so it can take some bashing.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. sapper
    Jul 11, 2001
    3,052
    NoVa
    my goal is to get so that i drive off a ledge and let the truck slide down on the fram/rock sliders.would it be possible with a 205 mayby?
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    If you use it for offroading only. No matter what transfer case you use, your putting the driveline angles to high. Like I said build a tubular crossmember, and weld thick steel on the bottom. You do this and your transfercase will be fine. Just angle the steel so it will slide not catch.
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
    Sounds like a good idea thanks. thats what i love about this site.
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    No problem. If you have any more questions just ask or e mail me.
