RAM AIR ?FOR OFF ROAD USE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Jan 6, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    THEY CAME OUT WITH A RAM AIR SYSTEM ON THE NEW CRATE ENGINES FROM GN I WAS WONDERING IF I WOULD BE GOOD FOR OFF ROAD USE BECUASE I WAS THINKIN WATER AND MUD MIGHT GET IN THERE AND GET CLOGED I DUNNO ?......
  2. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    The only ram air that i know about is on some sports cars and some motorcycles it has an intake that goes to a snorkle on the hood or in front on a bike and when you hit 60 mph or faster it presurizes(sp?) the air box and forces more into the intake and it does increase power but this would be useless on an offroad vehicle because of lack of speed. Think of it as a supercharger that uses wind force to increase atmospheric pressure instead of engine power to turn a rotor or vain to increase pressure like a supercharger. Ram air does not make as much power as a super or turbo charger but it is almost free extra power at higher speeds.
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    The one I think you are talking about is an add on intake and fuel injection system by a company I can't remember right now. It should be the ultimate and great for off road. Just hook up a snorkle to the intake, seal everything else real good and go swimming! Don't really know why they call it "Ram Air" must just be a marketing thing.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    SMP is right, the Ram Air is like ont he motorcycles - uses vehicle speed to force air through the air cleaner to the cyclinder - potentially at higher then atmospheric pressures. Wouldn;t do squat at 10 mph and less. They use these on 200 mph+ jap bikes.
    Actually, I'm not even sure if they still use them since they all went FI isntead of carb. I remember the carb's ZX-11 and others used them.
    -- Mike ( I have a bike and a truck - who needs a car? )
  5. Adrock
    Adrock 1/2 ton status
    214
    Marlboro, MA
    if you put a hood scoop on your truck it may boost HP a little. since you engine right now takes warm or hot air from the engine bay it is less dense. and the colder the air, the more dense it is, so if you put a scoop on your hood and place it about where your airfilter is, you engine will get colder air. Now i THINK this is how it works- you put the same amout of air in your cylinders, but since it is more dense, its like you are getting more air, which in turn gives you slightly more HP. I believe that is true. i have a hood scoop on my truck for use as a snorkel. when i close the hood, the hoodscoop has an airtight and watertight connection to the airfilter. i guess i could go to just about the top of my hood in water, but i havent made it anywhere close to that yet. hope that helps.
    Adam
    a.k.a. Adrock
    88 Chevy Blazer FI 383
    Feel the Thunder
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    There is a company (Air Inlet Systems) that makes a Ram Air Box. I haven't got one yet but it is something that is on my list of things to do if I dont do a TPI system.
    http://www.ramairbox.com/
    C'moe
    <font color=black>the blazer is "Back in Black"
  7. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    You may be thinking of the the newCrate motor that is fuel injected. This is easily adapted to a ram air application because of the throttle body at the front of the motor. There are 2 pluses for offroad use, on the fule injection, and 2 the ease to hook up a snorkel. Ram air would be a waste of money on and offroad truck unless you are doint high speed dessert racing
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  8. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Pace Parts sells a complete Big Block 502 with RamJet Fuel Injection. It is a complete drop in motor and it only costs $7,000! The picture in my signature is the ramjet engine. Or go to <A target="_blank" HREF=http://www.paceparts.com>http://www.paceparts.com</A>
    74 Blazer
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I dont think it would be a complete waste because you will be getting in cooler air, it just wont be forced in the intake during low speed, am I wrong???
  10. dyeager535
    26,982
    191
    "Ram Air" is less effective for the "ramming" effect it has on incoming air, as it is for COLD incoming air. As an example, cooling the intake air charge from approximately 150 degrees to 75 degrees provides a 30% power increase! Obviously that is no small amount. Stock underhood temps of 150 are easily attained, and with ambient air temp at 75, the more cold air you can ge the engine to ingest, the better. That is why cowl induction works so well. Functional cowl induction, not fake cowl induction. That is also why you have to be careful with open element air cleaners...they flow more, but they also flow more HOT air. Obviously the best trade off is a high flow cold air system, basically any that provides a straight path for large volumns of cold air to the engine.
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  11. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I guess that's why you see guys at the dragstrip with bags of ice on the intake between runs [​IMG]
