ram assist mounting ???
Discussion in 'The Garage' started by oll' bessy, Jan 31, 2007.
  1. oll' bessy
    oll' bessy Registered Member
    Mar 6, 2005
    14
    big bear, ca.
    working on mounting my 2" bore ram assist cylinder on my D60 w/ high steer. is it a 'safe' idea to mount it to the left spring plate? the plate is made from 3/4" plate so i know it is strong enough, im just not sure about the added load on the u-bolts and such. any thoughts?
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I wouldn't.
    I had high steer and I got rid of it because that was the only option I had. There is too many other steering components to make it work off of a tower. I run the ORD crossmember and still did not want to take the chance of the ram coming in contact with anything.
  3. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    This is how I will be mounting mine, except mine will be behind the axle.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Dis be mine.ORD crossover/highsteer and I dont have any issues with the ubolts :D
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    OMG...Chris?:eek1: :eek1: :eek1:
  7. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    What is the maximum force the ram can generare and what diameter u-bolts are you using?
  8. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Dood,those pics are old.
    My truck has been like that for a long time.Where you been? :D
  9. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    No idea and just some stock size ubolts I had made local :D
  10. sgarrison
    sgarrison 1/2 ton status
    Feb 4, 2005
    148
    Art's Bar and Grill Mt. Pleasant S.
    I made a plate that mounts to the pass. side U bolts to mount my ram. But I also made a bracket that ties in to it that uses the dif. cover bolts to locate it laterally. I haven't had any problems in nearly 12,000 miles.
  11. oll' bessy
    Mar 6, 2005
    14
    big bear, ca.
    not sure of the max force, its a 2" bore, not sure the presure the pump puts out. i have 5/8" u-bolts. was thinking i could mount it to the left plate and weld some braces from the axle up beside the spring plate, but not welded to the plate so it can still be removed.
  12. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I dont think you would need a brace.I wheel hard and my plate does not move.I check my ubolts often and I have yet to find them other than what I torque them at.
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I know you truck has been like that forever you wanker...I was surprised to see you around here. :D
  14. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Surprised to see me around here?
    You miss the two pager on my latest mod :D ?
    Chris
