RAM JET 350 VS. no warranty
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BMR, Jun 27, 2001.
  1. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    Well the plan WAS to buy a 87 350 for my 85 blazer and put a TPI/TBI system on it. I just got back from the Chevy dealer and as it turns out I can't do this if I want a warranty!! It has to be original application to have the warranty. And I don't want a Carb any more. My only other option is to buy a RAM JET 350 for $5265!!! with a 12 month warranty. Question is how good is this RAM JET 350? Is it worth it? Is there any other options? I really don't want to keep the Carb.
  2. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    for over 5 k that motor should come with a hot blonde who's wish is your command. Nothing wrong with the ram jet, but there are better deals to be had. Check around
    "IF YOU'VE NEVER BEEN STUCK.....YOU'VE NEVER BEEN WHEELIN"!!!
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Thought I saw an advertisement for this engine through Jim Pace (www.paceparts.com) for $4495. Still a lot more than I can afford but quite a bit cheaper than you were quoted.
    Smitty
  4. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    If your planning on spending $5k go with the gm350Ho and a Howell EFI, you could get both for under $4k
    "The more Beer , The Harder the Trail!"
  5. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    I can't get the GM 350 HO and put anything on it but a Carb, for the warranty it must be orignal application. I did see a cheaper price on that engine at Autocenter.com for about $4495 ship it to me for $204. So it will still make out better, but I would have too send any parts down to Texas where they are at if something is wrong.
    Does anyone have the RAM JET system or know someone how does? It's it worthless, good, troublesome anything? Am I going to buy a $5000 paperwieght or a investment?
  6. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    How much does the dealer want for an original replacement? Just wondering>...
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    $5k for a small block? Give me a break! You can build a really wild one for 1/2 that!
    Tim
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Which long block are you looking at...? I would recomend a short block setup w/ some worked heads to fit the system you want...TBI or TPI.. Most places cover a short block in terms of warranty unless you race it, use nitrous, redline it, super/turbo charge it, insane use type things w/ a stock block... I mean most likely thing to hapen is a spun bearing unless someone really screwed up. But broken rods and stuff would more likely be by useage... Also keep in mind if you plan to install and break in the block yourself GM greatly down grades their warrenty standards anyways... at least that is what I've heard. I would try and find a well respected engine or race shop and have them do the whole motor for ya... tell them what you want and what not... I'm sure it will be cheaper then 5 grand!
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  9. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    For an original replacement of a 350 long block I was quoted $1595. I found some on Autocenter for around $1300.
  10. BMR
    BMR 1/2 ton status
    Feb 25, 2001
    132
    Northern Colorado
    It would be nice if I had the means to build one. I lack the experience and the time. And my 305 isn't going to last much longer. In the future I do plan on building one but now is not the time. This engine comes with all the computer and sensors, plus it's all new. I don't have to hunt sh*t down at an bone yard.
    It's Part number is 12495515
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you want, come to my house. Not only will you leave with a new motor, we can make a campfire of $1 bills that you would have wasted spending $5k on a motor. It'll probably burn for a week.
    Tim
  12. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Isn't the Ramjet 350 a streetcar motor, built for impressive HP numbers at the expense of low-end torque??
    If I'm wrong I'll shut up...
    If at first you don't succeed, failure may be your style...
    [​IMG] Semper Maintenance!
  13. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I dunno, never drove one, but it has 400ft/lbs at like 3500, not too bad. Not like the fast burn 385, which peaks much higher in the RPM band.
