Ram Jet 350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jan 8, 2002.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have an 87 k5 350 tbi and i saw the trucks episode with big blaze and thats an 88 with the Ram Jet in it, i was wondering how dificult it would be to put that motor into my truck, also is that engine tuneable?
  2. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    i'm wondering the same stuff so i would like to know too.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  3. BI U JIMMY
    BI U JIMMY Registered Member
    May 20, 2000
    74
    From what I heard about the install, all you need is a fuel system to support fuel injection and a 12 volt source to run the computer. The same article also stated that the computer is an open loop type and will only work with what the engine comes with such as cam and heads. Pretty neat package though, wish I could afford it.
  4. Lee
    Lee Registered Member
    Dec 24, 2001
    30
    North Carolina
    I just received my ram jet crate motor today...It is in fact an easy bolt in but you need to get some additional parts with it when you order it
    1. It does not come with dipstick tube or dipstick
    2. It comes witha manual flywheel so if you run an auto you must order the correct flexplate and throw away the one that comes with it. (why you can't specify before you order is beyond me and probably why GM loses so much money)
    3. You need a starter to match the flex plate
    4. You need an electric fuel pump setup.
    I got mine from Scoggins Dickey (they advertise here) They could have told me that I needed to get these parts it would have helped out alot.
    Lee
  5. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    Very easy 4 wires and marked very well but I also had problems getting all the gas fittings so think 2 weekends to get parts and install
    And for the rest I side with lee
    GOODLUCK
    Patrick
    89 gmc jimmy 35" 10bolt front and back
    but the build up is on the way
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Very self contained motor, even has its own computer mounted on the rear of the manifold..........as stated, you get the proper high pressure fuel lines/pump combo and you are good to go.
    Only issue I see with it is it does not use an O2 sensor..........but they are now available from I believe Arizona Speed and Marine to enable the O2 sensor, and allow the computer to go into closed loop operation.
    <font color=blue>SWEET motors</font color=blue>.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You need to check with your state emissions folks before you drop the cash. That engine isn't certified emissions legal. So find out what the requirements are for your area first. It would suck to drop that much money into it and then not be able to register it! [​IMG]
  8. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    i couldnt afford the ram jet version of my engine, had my engine not blown i would have waited a few months till i had the cash for it. wiring is pretty simple, like everyone else said, converting the gas to electric pump will be the biggest headache. and even then thats not very hard.
    definatly a good investment.
