rams horn style exhaust manifolds?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Aug 30, 2000.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I am thinking about replacing my headers with factory style exhaust manifolds (I am not happy with the inexpensive Hedman's that I recently installed). Does anyone know if the rams horn style manifolds used on Corvettes and similar to some of the earlier model trucks will fit on a 78 Blazer. Since they exit in the center I am concerned about crossmember clearance. I don't have a set to test fit, but it looks like they might fit.
  2. Grim-Reaper
    7,385
    Atlanta
    Should work fine but the only down side is the plug wire routing. Still better than the headers. Jegs and summit also sell a set of "Block hugger" style headers that you may want to look at. They locate the exhaust flang in about the same location as the rams horns and would be cheaper than buying new rams (getting rare in the junk yards) and flow better. Jeg I know sells then already ceramic coated for a bit more.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You can buy new 2 1/2" rams horns through GM Performance parts. Pace sells them for about $70 each.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    What is Pace? And how do you get ahold of them? Thanks.
    ken
  5. Blazer1970
    1,600
    Old Mission, MI
    Jim Pace Pontiac in Ohio. They sell GM parts at a discount. http://www.paceparts.com or 800.748.3791
    The part # for the manifold that you want (works on both sides) is 3797901. This manifold was designed for a '63 Corvette. There is a cast on generator boss that you may have to cut off, but cast iron cuts like butter with a hack saw.
    Tim
