Ran my rig out of gas. Will not start back up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Aug 26, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Put 5 gallans in the one tank and cranked it a few times. Didn't get anything back up to the filter by the carb. What the heck am i missing???
    thanks mike
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I'm pretty engine dense but maybe try priming it
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    is it a gas motor? If so dump some gas down the carb from a can (soda can). Then try starting it. That is what I do when I run my Jeep out of gas. Don't dump a whole can but just a couple ounces then try to start it. It will probably fire up then keep the throttle open some so the engine idles high and gets the fuel pump pumping again.
    Harley
  4. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    And if that doesn't work check the fuel pump relay. You should hear it prime/turn on when you turn the ignition on.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    His bio says an 84 so that should be a carb with a mech fuel pump. If it is injected then spray some starting fluid down the throttle bores to help kick it over.
    Harley
  6. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    It's possible (if after priming it that it still won't pull fuel up) that some sediment or something in the tank got in the line or clogged up the pick up. If so, you can blow back through the line with air.
    OR... in an even more rare case, you may not have ran out of gas, but your fuel pump could have just gone out. It's happened to me before.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I will give it a try. Its not the truck in my bio. It is a 1980 3/4 ton 4x4 with a 350.
    thanks mike
  8. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    If after all those checks it doesn't start try checking the little fuel filter in the line up by the carb (it would be right where the line bolts to the carb big nut looking thing with a cone screen filter in it) if it has one I had a piece of silicone from somewhere stuck in mine and a buddy found it after I gave up.
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Cool thanks I will let you guys know how it goes.
    mike
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK did it all. nothing worked. I put 100psi in the line and still did not work. Anyother ideas?
    Mike
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Not tryin to be a smart arse.. But you said you put it in one tank.. So I am assuming it is a dual tank truck.. Do you have the switch on the right tank..???
  12. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Maybe that's his problem, he put gas in the LEFT tank but has the switch on the RIGHT TANK. /forums/images/graemlins/histerical.gif
    Anyhow, yes as Dan said, make sure you have the switch going to the correct tank that you put fuel into. /forums/images/graemlins/thumb.gif
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Its on the right tank. This has got me beat, still cant get it.
    mike
  14. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Those switches do go bad.. But some gas in the left tank and switch it over to there..
  15. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i was told on the older switches, that if you run out, it won't switch tanks. not sure how true it is. my 83 switched tanks even when empty. /forums/images/graemlins/dunno.gif
    try puting gas in both tanks and try it.
  16. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I will give it a try. thanks
  17. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    I just put an engine in my '79 blazer and I couldn't get fuel to the carb. I blew air thru my lines, changed my fuel pump and still nothing. I just put 15 gallons of fuel in the tank so I had fuel. Then I figured it out today, if you have duel tanks make sure your switch is on the correct tank and take the fuel line off the trottle body, take an air hose put the blower nozzle on it wrap a clean rag around it to make it air tight then blow air into the tank, make sure someone is watching the fuel line to tell you if fuel is coming out then stop the air,put the line back on and try to start it. It worked for me.
  18. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    our old dually chevy had a fuel pump problem in one tank(88' tbi). it would go out once and awhile, but then work later on.
    once we thought it was broken, couldnt get it to fire. then someone noticed the rocker switch had been kicked and it was stuck in the middle . try flipping the switch back and forth.
  19. Jonny-K5
    May 27, 2003
    1,654
    SoCal
  20. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks guys some more stuff to try. Mike
