Rancho 9000 shocks for 1 ton
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by a87ss305, Mar 24, 2002.
  1. a87ss305
    a87ss305 Registered Member
    Apr 25, 2001
    50
    Clear Lake, Iowa
    Why doesn't Rancho list a 9000 series shock for the rear of a 1 ton yet they list a 5000 series (RS5134)? In fact if you look at the specs (extended length, collapsed length, upper and lower mountings) the RS9012 is nearly identical. Why doesn't Rancho recomend it?
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    When you order the 9000 series shocks they come with a varity of mounting hardware. they even give 1 shock stud for the upper rear mount with each shock. Basically when you order the shock you just use what you need for mounting them.
