Rancho 9000's - theory on which setting for trail rides
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Mar 22, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Rancho 9000\'s - theory on which setting for trail rides
    Wondering what you guys think...............trail ride conditions, probably a bit of mud, mostly slow speed travel. What setting do you guys use? Have sway bar disconnect up front and 55Willy's custom rear shock relocation with 9012's, if that matters.
    Thanks.
  2. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    Re: Rancho 9000\'s - theory on which setting for trail rides
    hey blazzin i set mine on 2 for the trails but i only have them on the back for now. i like 2 because its soft and seems to soak up bumps alittle better
  3. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I agree...the lower the speeds the less dampening I would use, as long as it isn't so soft you feel the same bump three times, which shouldn't be a problem with the RS9000's.
  4. BurbinOR
    5,829
    Oregon
    Thanks guys, I'll start out on 2............/forums/images/icons/smile.gif
