Rancho lift installation help...how do I line up the springs (pics). help
Discussion in 'The Garage' started by jakeslim, Jan 25, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
  2. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Looks like you need to jack the truck up by the frame. that will line your holes up closer
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    cut your tailipe, and jack up the frame, or lower the axle.
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Pull the other spring off and lower the axle.You may also need to lift the rig higher.It also is easier to put the springs on first then bolt the axle to the springs.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    First, unbolt the spring from the axle. You don't need to be wrestling with the weight of the whole rearend while you try to get the springs in place. /forums/images/graemlins/shocked.gif
    Next align the eye at the front end of the spring with the fixed hanger and insert the bolt. Put the nut on, but don't tighten it yet. Then it looks like you're going to have to jack the frame up higher to do the next step. /forums/images/graemlins/frown.gif You need to be able to align the rear eye with the shackle. It looks like the spring is hitting the axle before it can make it into the shackle. Once the spring is bolted into place, then you can attach the spring to the axle.
    Now do the other side, then go back and tighten up all the bolts and nuts. It's easier to shift things around a little if you leave them pretty loose until everything is back in place. /forums/images/graemlins/thumb.gif
  6. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    just pull on that sucker as hard as you can /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/rotfl.gif
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    looks like your tailpipe is in the way,the truck is not high enuf and the 300 pound axle is bolted to the spring.that in itself would be hard enuf to get the spring in.the spring itself weighs in at about 75 pounds.if you dont want to unbolt the axle you will still hav to lift the rear of the truck about anether fott it looks like.that is how i see it.good luck.it would also help to have a friend who can help move things a little with you lining up the holes for the bolts.
  8. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    thanks fo the tips. DONE(with rear)!. Just in time as a bit of snow is falling...ouch. Next weekend....front of my ever demanding vehicle. The old springs literally fell apart when loose and the blocks looked terrible. Truck sits just as it did before with 6 inch blocks.
    Thanks again and I will most likely seek help next weekend with the front end. Friends? all have never picked up a wrench in their life. NJ people for the most part are "pay someone else to do it" kinda folks.
