Rancho steering dampner?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Espen88k5, May 17, 2001.
  1. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Did I do this right. On the instruction sheet it looks like it should be angled more uppwards. The only way I can do that, is to move the tierod bracket inwards and not facing down like the instructions say. Anyone else done this?
    [​IMG] <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    My dual setup has the tierod bracket faced inwards..............that is how I have seen every other setup done.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    My stock one goes from inside to out. Where the stab attaches to the tie-rod over toward the driver side tire. Does this make any difference?
    That looks like the stab may hit the diff cover whene you turn full right?
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  4. Espen88k5
    Feb 19, 2000
    981
    Norway
    It works well the way it sits now, and it doesnt bind or touch anywhere. The reason I ask is cause the instructions said to have the tie-rod bracket facing straight down like it's now, but the picture in the instructions shows the shock at a much steeper angle uppwards. What's stopping me from turning the axle bracket further upp is that the cylinder part of the shock is touching the tie rod.
    I could cut the old steering shock bracket on the axle, off and twist the tie-rod bracket back and get a steeper angle that way, but I'm thinking it isnt necesary??
    Thanks for your help and advice!
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sure looks to me like it's just waiting for intimate relations with a rock.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
