random check engine light with no codes...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jpaitala, Oct 28, 2003.
  1. jpaitala
    jpaitala Registered Member
    Sep 1, 2003
    33
    Imatra, Finland
    I have a '89 K5 with 350TBI and manual trans.
    The problem is that I randomly get check engine light but no codes after the light. I previously had to change MAP-sensor, IAC-valve and O2-sensor. I had trouble codes back then and got rid of them by changing all these sensors.
    But now no codes... /forums/images/graemlins/confused.gif
    If I drive more than 20-30min a row, then most of the times I'll get check engine light, but not on shorter trips.
    What could this be?
    Thanks.
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Sometimes during a situation where the motor is idling too low and is about to stall I have seen the check light flash and no codes
  3. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Pull off your egr valve and make sure the that the egr port is clean, I have seen a plugged egr set a check light and not store the code. (darn! mazda)
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like your Dist module may be going bad. When they go bad they will set a code 12.(No spark signal)Code 12 acually does not mean everything is OK. Like many people think. Code 12 comes up every time you check codes because the ign is on but engine is not running therefore not sending a spark signal to the ecm. The code 12 also indicates the ECMs Diagnostics are functioning.
    Dist modules, when they start going bad usually start giving troubles after they warm up.
    Lighting the CEL, missing, hard starting, stalling. with no codes(except 12) are symptons of a bad module.
  5. jpaitala
    Sep 1, 2003
    33
    Imatra, Finland
    No stalling, no difficulties to start, no missing... Only check engine light. The egr could be it, I have not had time to check it, but I'll check it.
    Thanks for the reply's guys!
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Sometimes my check engine light will come on after I drive on the highway for a while. It is the egr valve. The computer just may not be storing that code properly.
    -Harrison
  7. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Agreed EGR.
    When you pull codes do you get code 12? You should see code 12 no matter what.
    -Dan
  8. jpaitala
    Sep 1, 2003
    33
    Imatra, Finland
    Yes, code 12. So the "system" should be working...
  9. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    I second the possibility of a distributor module problem.
    You might pull the distributor cap and make sure that the module still has thermal grease - perhaps it's getting too hot during your longer drives and giving you that code 12?
