Random Questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shane, May 12, 2001.
  1. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    1. How do I know if my torque converter is locking up? Any way to test it?
    2. What the hell is a TCC and how do I make sure its working properly?
    3. How often should you change the little filters on the injectors?
    4. Is me tranny electronic or vacum controled? It is a 91 blazer with a 4L60 (700-r4)
    5. Why would my brake light come on a weird times? Some times when I`m on the brakes and sometimes just cruising it will come on. Once on it will stay on until I restart the truck.
    Haynes manuals suck - big time! About as useful as two tits on a board if you ask me...
    Sorry for all the questions but this stuff is bugging me.
    Shane
    Just keepin it Canadian[​IMG]
  2. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    . How do I know if my torque converter is locking up? Any way to test it? <font color=red> you can usually feel it lock + rpms drop</font color=red>
    2. What the hell is a TCC and how do I make sure its working properly?<font color=red>Torque Converter Clutch</font color=red>
    3. How often should you change the little filters on the injectors? <font color=red>little filters?</font color=red>
    4. Is me tranny electronic or vacum controled? It is a 91 blazer with a 4L60 (700-r4)<font color=red>vacum & TV cable
    5. Why would my brake light come on a weird times? Some times when I`m on the brakes and sometimes just cruising it will come on. Once on it will stay on until I restart the truck.............<font color=red>could be the abs system</font color=red> <font color=blue>on the manuals I have a chiltons and it seems ok part#(8055)28624......thats the # at the top of the book</font color=blue>.
    <font color=red>1991 GMC Jimmy 350tbi 3.42</font color=red>[​IMG]
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Torque coverter lockup:
    If you have a tach, you will se an RPM drop ~200RPM.
    You should be able to hear/feel it also
    Check out your local shop with a portable diagnostic computer-plug it in and take him for a ride. The computer will show RPMs and more. (did that method when I blew the sprag, TC was cycling up and down)
  4. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Shane there's a search feature here. Can learn tons from going through things like 700r4 lock up problems, TCC, Torque Converter Clutch.
    Once you get a good thread click flat and have at it. I do believe it is both vacuum and electrically controlled.
    Good Luck
    Why do you ask? What are your symptoms?
  5. shane
    May 6, 2001
    162
    I was going through my haynes amnual and it showed a picture of a little filter that is on the end of the injector where is sits down in the TBI body. I can scan the pic if anyone thinks I`m crazer than normal [​IMG]
    I`ll get on a search right snappy...
