ratios
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4x4k20, Aug 26, 2001.
  1. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    anyone running different ratios in there 4x4s if so what the closest you can run
    4x4k20
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Do you mean a different ratio in the front and back? As far as I know, you can't........
    <font color=blue> MEAN DAD WITH TWO BAD KIDS<font color=blue>
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I belive you can only go 10 percent on the differnet ratios. Like 4.10 and 4.09, or 3.40 and 3.42, or 3.70 and 3.73. Hope that helps. You could get away with more if you only used 4 wheel drive in heavy mud where there is no traction. If you used say 4.10 in the rear and 3.73 up front and used it on hard packed dirt you will destroy the transfer case very quickly.
    86 Jimmy 4"lift 35"MTRs locked front.Other cars 69 Firebird w/525 hp,and 70 GTO <a target="_blank" href=http://www.geocities.com/modifierperformance>MY vehicles</a>
  4. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    yes' i here that some people do like run 410 rear with 373 front just wondering if anybody here runs different ratios like this with any problems
    4x4k20
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Not recommended unless you like very deep mud.
    Rene
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup 10% is the is the biggest axel ratio difference you can go without causing damage to most transfer cases.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=orange>Charter Member of The Too Much Fun Club</font color=orange>
  7. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    That advice also assumes that you are running the same size tire on both the front and rear of the vehicle. I think there was some kind of pink-colored hybrid truck in one of the magazines (possibly a TTC applicant?) that ran different gear ratios front and rear, but also had substantially smaller tires up front.....that's how he was able to get away with it.
    -Greg72
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    10 percent ????!!!!!!
    Do you realize that would be like running 4.10's on one end and 3.73's at the other!!! I don't think that would be recommended.
    Maybe you are thinking of 1%, which would be more like the difference between 4.09 and 4.11 gears.
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    10%?!? You guys gotta be kidding me! According to most sources, 1-2% variance is about all you can do safely. For example, 4.09 front and 4.11 rear. That is [((4.11/4.09)-1)*100] 1/2% difference. 4.10 in one axle and 3.73 in another is [((4.10/3.73)-1)*100] 9.92% variance.
    According to www.ring-pinion.com, 1-2% is the most difference you can safely run.
    As far as the 1-2% variance or the difference in gears brekaing the tcase, you guys need to check out this article &gt;&gt; <a target="_blank" href=http://www.ring-pinion.com/t-myths.html>Myths about Diffs</a>. It will make many things a little clearer.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    I run a 4.09 front with either a 4.10 or 4.11 rear.(cant rememebr it has been a while) I have no problems, but that is pretty close and how mot come from the factory.
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
