Rattle can body work
Discussion in 'The Body Shop' started by justwhatido, Aug 22, 2004.
  1. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Took my son's pick up to a body shop to see about the hood and having two spots where the air defletor rubbed paint off repaired. The spots were approx 3 inches long, an inch wide, and rusting. They quoted just under $150 and would need the truck two days.
    Being black, the smoothing is a chore as any blemish shows.
    I squeak when I walk, so I went to Walmart and purchased rattle cans of touch up in the proper code, primer and clear coat. Went home and in a day sanded it, primed it, sanded the primer, sanded, primed, sanded, black, sand, black,sand, black sand, clear coat, sand clear coat. Then wet sand with 1600, use rubbing compound, wax the next weekend and you can't tell where the repairs were done.
    Never tried real painting before. That was a rush.
    /forums/images/graemlins/pimp1.gif
    Fred
  2. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    /forums/images/graemlins/waytogo.gif
  3. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    if you want to get really redneck, pop a hole in the spray can and empty it into a spray gun and spray the paint that way.(i was too cheap and lazy to go buy the real car paint that day).
    sprayed my rear bumper on my Ram that way.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    wouldnt the spray can blow up if you poked a hole in it???
  5. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    nope, its sorta like shaking a can of pop up and popping a hole in it.
