Rattle can
Discussion in 'The Garage' started by shaun, Apr 29, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Pics of rattle canned trucks and blazers. Lots o pics. All you do is sand, tape, and then paint right?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    after you sand it you should take a cloth with thinner on it and wipe down the whole area to be painted then paint it /forums/images/graemlins/thumb.gif
  3. shaun
    Apr 22, 2003
    745
    How far do I need to sand it
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I would say down to the primer but I am not an experienced painter. I sanded down to the primer on mine and had no problems so far. Just touch up jobs though /forums/images/graemlins/whistling.gif
  5. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i just did mine with flat black... only got the front clip done so far...... I just sand everything smooth, then throw on some primer and sand again then paint...... When you go to the store to get your paint.. Hit up the cleaning supplies area, and take a Few caps off of some glass cleaner.. it sprays about a 3-4 inch diameter circle, instead of a 1 inch dia. circle.
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Check my webshots link below. It's a camo paint job done by the past owner..needs /forums/images/graemlins/ignore.gif a touchup
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I just wiped down my truck with a damp rag and painted. Worked fine. I didn't want to sand it. The paint has the body sealed. I didn't want to go down to primer and risk exposing the trucks metal to rust. Not to mention it was too much trouble....
  8. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Here is mine it was primered gray when i bought so I just sanded it down smooth then painted. [​IMG] /forums/images/graemlins/thumb.gif
  9. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    I'd start with a good pressure wash, to remove dirt & grime, this will prevent from rubbing these things into the old paint. Then wipe down with a pre-cleaner (thinner) to remove oils, grease, silicones, super-sauces (Armor-all, etc.), sand or scotchbrite enough to scuff the surface paint, to give it "teeth" for new surface to "bite" into. Scuff first, paper & tape last just prior to painting (helps from sanding your taped edges & trapping sanding dust in your masking materials).
  10. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Make sure you wet sand the primer before painting it. If you have any rough edges make sure oyu featheredge them. In other words your hand should glide over the whole body and not feel any roughness throughout the whole body. I have used rustoleum primer with good results. Before your ready to paint you will need to clean the surface with a degreaser of some sort. I use this stuff from 3M that you can pick up at a parts store, just for degreasing your vehicle before you paint.
    If you want a professional look, remove all handles and bezels before taping. Only thing I tape up is windows. If you get any overspray anywhere you can use thinner to remove it.
    Hope this helps. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  11. shaun
    Apr 22, 2003
    745
    Thank all of you for the tips I planning this real soon. I am tired of my Truck being multiple colors.
  12. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Have you decided what color you're going to paint it?
  13. shaun
    Apr 22, 2003
    745
    No any suggestions? I am deciding between flatblack or actually taking the time to paint it a color. Rims are black and that is the only thing set. All my accents are chevy blue (calipers, skidplate, t case, tierod, etc soon the roll cage ,when i get one) what do you think will go good. /forums/images/graemlins/whistling.gif
  14. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    How do you all keep from having spray lines?
    Also has anyone ever put a coat of clear on top of the spray paint paint job.
  15. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    For a rattle can job black, white or camo seems to be the most popular, Im not sure how well a color would hold up to fading. Ive always liked black myself because when you get slight surface rust from stone chips it doesnt show like with white. /forums/images/graemlins/dunno.gif
  16. shaun
    Apr 22, 2003
    745
    So you say sand it one or two coats of primer sand it and then some flatblack. Or gloss black. Im not doing the camo thing.
  17. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Sounds good to me. I painted the lower 1/4 of my 70 flat black, the rest is original yellow, looks good. I just sanded slightly, primered and painted. Flat black doesnt run easily.
  18. shaun
    Apr 22, 2003
    745
    Good deal then thats what I will do. Do you have any pics
    Does anyone have pics of flat black rigs?
