Rattle in front driver side
Discussion in 'The Garage' started by 91k5NC, Aug 19, 2002.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    When im going down the road and hit a bump sonuds like the hub is rattling /forums/images/icons/frown.gif , done it after had new rotters put on, any suggestions.
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I'd say dig in ASAP...I noticed a clang on my 85 only when I hit potholes. I was about to go on a road trip so I decided I better check up on this noise and it turned out I only had one guide pin holding the brake caliper on... Also check your wheel bearings...err rather the torque on them....easiest way to check anything in general up there is to jack up the probable cause side....take the tire with both hands and check for play in and out grabbing the sides of the tire at 3 and 9 o'clock and back and forth wobble grabbing the tire at 12 and 6 o'clock.....
  3. 91k5NC
    Jul 12, 2002
    206
    Durham Nc
    thanks alot /forums/images/icons/grin.gif , ill do that and let you know.
  4. 19Jimmy87
    19Jimmy87 Registered Member
    May 9, 2002
    65
    Kalamazoo, Michigan
    Funny, but this happened to me. It ended up just being the center cap around the hub was missing a couple of bolts.
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Mine was the center cap too. Had to bend the tabs on the back. Sure sounds bad though.
  6. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    There is a little rubber piece that goes on the guide pin bushing to prevent ratteling. This may have been damaged or lost during the installation.
