Rattlecan How-To: Stripes?
Discussion in 'The Body Shop' started by TSGB, Mar 8, 2007.
  1. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I've got this:
    And want to turn it into this:
    I've never done anything more than hose with a spray can, so I'd appreciate a good walk-through! Paint removal? Paint to get? Other supplies? How do I manage this? I would think a flat coat of black, then somehow tape it off for yellow. :dunno:
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    My BIL just taped his with blue tape and spray painted his stripes -
  3. Craig Artzner
    Craig Artzner 3/4 ton status GMOTM Winner
    Dec 16, 2006
    6,843
    Northeast Ohio
    Painting it black first and then yellow sounds like a good start. You're just doing a driveway rattle can job, right? Nothing fancy?
    I rattled canned my very first truck (the one the burned up, see my photo album) about 5 times in as many different color combos. I would use blue tape for the initial black coat to cover whatever you don't want painted black and then leave that tape on when you do the yellow.
    One thing you want to watch is what you use for tape when you're masking for the yellow. Some masking tapes will peel that flat black right off. Whenever I had to apply masking to something that was spray-painted I used masking paper, which can be gotten at you local paint store. It's just a roll of paper that comes in different widths that has some light adhesive on one edge. Kind of like a Post-it note. It should be light enough not to peel your paint.
  4. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    I thought it was light color first, then darker color :dunno: ??!!
  5. Craig Artzner
    Dec 16, 2006
    6,843
    Northeast Ohio
    I was just thinking that his truck is already a dark (multi) color anyway and the black would uniform it. I wouldn't have suggested it had his truck been a lighter color. He would have to use more yellow paint than black paint to cover that whole truck...
    Hey CDA...are you following me around just to counter my posts now? :haha: :D
  6. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    So I don't need to worry about stripping any of the current paint? Can I get away with $1 cans of paint?
  7. Craig Artzner
    Dec 16, 2006
    6,843
    Northeast Ohio
    I would only worry about stripping stuff that's already peeling, maybe just run over it with some sandpaper to rough up any shiny areas. Then just give it a good wash and dry. Then tape it up and have fun with it :D
    I'd get a brand name paint if it were me, but you could get away with dollar-store paints.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Do yourself a favor.. buy yourself a roll of fineline tape... for straight lines, the olive green...
    scrub the whole thing down with a scuff pad and Ajax, rinse, dry, have at it...
    PM me if you need any paint or prep tips...
  9. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    How long will it take for the beast to dry between coats? How long after before I can hit the road?
    Is fineline a brand name? Where can I get it?
    Also, how many cans of each (yellow and black) should I expect to burn?
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    between coats, 10 minutes.. before taping with fineline, eh, give it awhile.. if its gloss, longer than semi.. but at least a couple hrs... you want to be able to not leave a thumbprint in it..
    3M fineline tape..
    http://www.autobodytoolmart.com/pc-11370-489-3m-scotch-fine-line-tapes.aspx
    quantity? no clue, 5,6 cans of each, probably more..
  11. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Wicked sweet. I'll gather up the goodies, and hopefully the weater will be good to me next weekend! :waytogo:
    Thanks for all the help guys!!!
  12. cbbr
    Jul 17, 2004
    14,681
    Only here can you get professional advice on spraypainting a truck.:haha:
  13. cbbr
    Jul 17, 2004
    14,681
    We finally beat you down with the spray paint questions?:D :bow:
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I can hack it up with the best of em... :wink1:
    Thats the way it goes at work, big dollar guys, do it right the first time no matter what it takes. Then I get my low budget guys, they get 2 prices, the right way, and the cheap way... :haha:
  15. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    I wonder which category I fall into? :thinking:
    :haha::haha::haha::haha::haha:
  16. Craig Artzner
    Dec 16, 2006
    6,843
    Northeast Ohio
    Probably the cheap category...but you get to do it yourself...and it is fun. I'd come over and help you tape 'er up if you lived closer :D
  17. cbbr
    Jul 17, 2004
    14,681
    I don't know. If its a trail only truck, this might be more than most would do.
  18. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Here's something I just thought to throw out there that noone here has ever mentioned and can/maybe will apply to some...
    For all those who just mask things off in newspaper.. Tho you'll be fine for many projects, some paint, some, mostly catalyzed car paints, can't say I've ever seen a rattle can do it, WILL bleed thru newspaper...
    Can be an issue... paper bonded to windows, etc.. can get messy... Thus, why you don't see bodyshop's use newspaper... Well, that and masking paper is faster.. Their are also MANY different kinds of masking paper, surfaces, properties, etc...
    :This body tip has been approved by dinosauric vert dogs in north america:
  19. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    I wouldnt do the yellow on top of the black, I would paint it black, mask out where you want your yellow stripes, and do a very bright primer, this way the yellow is a bright yellow, not a bogged down mustard yellow.
    DONT USE NEWSPAPER near you paitning either, the ink comes off really easy.
    Hope that helps
  20. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Hmmm, I didn't know the body shop was big enough for echoes.... :wink1:
