rattling 465 / 205
Discussion in 'The Garage' started by jackedjimmy350, May 8, 2006.
  1. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    when i put in the clutch or let off the gas at higher speeds - 35 mph or greater - i get a loud rattling, not so much grinding, noise coming from my tranny / tcase.
    any ideas?
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Mine does this also, I was thinking it might be the input bearing on the tranny or at least that's what I was told when I asked IIRC. She's a trailer queen now and never get's above 25 MPH, problem solved :)
    It could also be a driveline issue vibrating through your tranny, transfer case?
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Or you mean pilot bearing?
  4. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    To be honest, i do not know, but here is what I woudl check.
    Cross memeber
    4 bolts on the bell housing
    SM to NP adapter
    Did you trim the hole for the shifter big enough and is the shifter itself causing the rattling (the linkage on mine makes a crap load of noise)
  5. kzx636rr
    kzx636rr Registered Member
    Jan 26, 2006
    6
    new jersey
    i have the exact same problem. i have a 465/205 setup too. mines gotten worse though, its doing it now even when you don;t let off the gas. all i have to do is be in mid RPM range and the rattle is loud as hell. if any one has any more ideas i'd appreciate it to.:confused:
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Mine does it as well. From what I have heard it is primarily caused by driveline vibrations. My guess is none of you with this problem have CV shafts in the rear and that would probably fix your problem. That's what I am hoping anyway.
  7. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Mine also has one he!! of a vibration on coast,but get this, only in 2wd. Currently lookin for a fixed yoke or a SLE to solve this problem.
