Razorback axle clamps for your 14BFF.
Discussion in 'Vendor Forum' started by cybrfire, May 14, 2006.
  1. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Here's a piece we did up yesterday.
    Couple things to note though. I will be trimming down the bridge supports to make for more clearance.
    These will be supplied with GRADE 9 Hardware. 7/16" bolts, pinch lock nuts and washers.
    Everything you see here is 1/4" thick material. The tubing is DOM.
    From here we will be moving into a bolt on shock mount for our Shock mount inboarding kit.
    We will also continue development on our Bolt on Truss/antiwrap system which by the way isn't far off.
    Soon as I can get some figures together we'll get these on the website.
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    I like, do tou think it clamps hard enought to be an anti wrap for my truck?
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I'll give you my personal guarantee, it clamps hard enough to be an anti wrap in any truck. Not to mention the antiwrap/truss setup will be tied into much more than just the clamps. These are basically for the ends of the truss so that it doesn't need welding to the axle tubes.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    What about for a 60? It looks like a possible way to mount a ram. I was going to make a modular setup pretty much identical to that. I have two axles I need to do this for, a HP60 and a front LP60.
  5. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    All depends on the availability of tubing but I don't see it being any more of a problem than this was.
  6. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Any idea on how much and what axles you will be making them for?
  7. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I'll get some numbers together today.
    As for what axles, I'll do them for a D60 for sure and demand will dictate the rest.
  8. Gravel Maker
    Gravel Maker 1/2 ton status Vendor
    Feb 6, 2006
    2,572
    23
    Sacramento, CA
    Very interesting idea.....
    Lots of good uses, nice job.....
  9. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Thanks!
    These will hit the website with an introductory price of $45 per clamp plus shipping. That includes the hardware as well. One thing I will be changing is the plate that the bolts go through will be swapped from 1/4" to 3/8" thick material and like previously stated, the razors will be cut back a bit to improve ground clearance.
    Keep in mind these are easily altered to suit your needs. Bolt on anti wrap brackets, Bolt on link mounts, bolt on shock mounts. I'm sure there is more ideas but that is off the top of my head.
    I'll try to post up pics as some of the customizing is done.
  10. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    I'd be interested in something like that for a D60 rear axle...
  11. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    I like them as a shock mount. Easily adjustable to get the perfect amount of needed movement.
  12. chosen(1)
    chosen(1) 1/2 ton status
    Nov 19, 2002
    206
    Michigan
    For those of us that don't weld all that well, will you be offering a bolt-on shock mount option for the inboarding kit? Because I will be doing this in the near future, and that would make it alot easier for me.
  13. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    these would be good for a modular truss system. I can weld ok... but I'd rather not weld much on my axle housings with my stick welder. Lots of heat tends to warp things... even very heavy walled tube. At any rate, I think a new version of the Guardsman and rear diff cover that allow a truss to be tied into them (simple, flange sticking up with holes/welded on nuts) easily would be pretty cool. I am going to need some kind of anti-wrap bar and a truss that was bolt on would be handy. I could mount shocks on it, my wrap bar, limiting straps, pretty much anything.
    j
  14. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Yep! I will add these to the website very soon. Just not sure how to list them as of yet. Additions such as shock mounting to the axle clamp won't change thier price much but there is so many possibilities its hard to know what to list. I may put them up as a base clamp and a call to order for custom applications.
  15. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I'm working on this as we speak. I have some ideas that I want to try and get fabbed and once its all said and done I'll get it going on here.
  16. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Looks awesome as always Kurt. :thumb:
    But talk to me like I'm stoopid. What the hell are Grade 9 bolts? :dunno:
  17. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    they spent one more year in school than grade 8 bolts...
    enough with the bad jokes, grade "9" bolts are quickly becoming the next recognized standard, a step above grade 8. basically, stronger. To my knowledge however, there is no formal "grade 9" standard as there is with 5 and 8. Someone correct me if I'm wrong, I'd like to know!
  18. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Seems the Grade 9 stuff has an average advertised tensile strength of 180-190,000 psi. I don't remember the numbers off hand for the grade 8 but I believe they are advertised on the average from 150-160,000 psi. and sometimes higher yet. There is quite a bit of variance from one company to another as to what they say there bolts will and won't handle.
    There is supposed to be a set standard for all of this stuff but I don't think its very tightly regulated.
    I am pretty picky with the hardware I select for the stuff I build. These Grade 9 bolts are different in may respects than grade 8's but in alot of applications it just isn't necessary. There not cheap either.
  19. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    ok i have to ask a ignorant question here. What are these clamps used for? I am hopefully doing a 14 BFF swap into my blazer over the weekend. Just curious.
    Jeff
  20. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    lots of different things actually. Stay tuned for some pictures.
