RCA's with speaker wires?
Discussion in 'Audio' started by KrebsATM02, Aug 15, 2000.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    RCA\'s with speaker wires?
    Ok, I have finally come up with a solution to my dilemma, I just don't know about interference. Will speaker wires interfere with RCA cables if they are ran parellel to each other? I know power wires will but i don't know if speakers will. Thanks - Doug
    Doug Krebs
  2. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Re: RCA\'s with speaker wires?
    Not of you have good speaker wire and good RCAs
  3. istallion88k5
    istallion88k5 1/2 ton status
    Jun 20, 2000
    139
    Cincinnati, Oh
    Actually if you have great quality RCA's even power wires will not interfere. I personally run 12 gauge phoenix gold speaker wires and stinger hi quality RCA's without any problems.
    If it aint a Chevy don't raise it up!
  4. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    If your RCA cables are shielded, which most quality cables are, you won't have a problem. If you ever have to run a power wire near a speaker wire, have them cross at a 90 degree angle, and that should reduce or eliminate any interferance.
    '89 K5 Silverado 4" lift w/BFG 33's
  5. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    It really doesnt matters weather if wether or not you have good or cheap rcas. Motor noise that you get from running a power wire to close to an rca cable comes from RF signal being radiated by the power wire. Usually this is very rare, as a matter of fact 90% of the time the nois that you hear is coming from a ground problem. Either you have a componant that isnt grounded well, or it has bad grounds inside on the board. It can also come from there not being enough voltage for your source and it is trying to pull voltage from other componants. So the answer is, NOISE comes from all sorts of things. But not from running your speaker wires with your rca's.
