Re-arching of the springs for added height?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RJB44, Jun 8, 2006.
  1. RJB44
    RJB44 1/2 ton status
    Dec 3, 2005
    238
    Northern Virginia
    I am looking to put a set of 33' on 1991 Blazer. It actaully has pretty decent clearence now with stock 31', but just want a little more room, perhaps 1-2 inches. I don't want to add a lift kit, or blocks. looking for somewhat of a stock looking height with 33's. I have seen stock blazers with 33's on and they really fill out the wheel wells.I had a factory plow package on a 89 blazer I had about seven years ago which gave it a slightly higher look in the front because of added spring. I liked that look, if I could have only made up for the difference in the back, it wouldn't have looked like it was sagging all the time.
    Your thoughts on re-arching the springs? Cost effective? Remember this is 1991 at 15 years old
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    that idea has been covered before. and it is a big wast of money. it wont last long and if thay show signs of rust build up at the center pin area thay might also break when bend up. and you can only add just so much arch before the shackles wont line up cause the spring is arched to far.
    grab a 2" lift and be done with it. but sub the rear blocks for a 2.5" flip kit in the rear. will get you better ride and no block in the back.
  3. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    I just replaced the front springs on my 89 with a set of rough country 2" springs and got a set of rear 2-2 1/2" from superlift's ebay scratch and dent store.My blazer now sits just perfect with 33s on it :D Now i just need some new tires.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Check off road designs website for zero rates for the rear. That will help level it a bit. Rearched springs ride like crap not to mention all the other problems that can be associated with them
  5. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    You could add zero rates or do add-a-leafs too. That will make it sit a little taller.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you want to add 2" cheap you can do a set of full length add a leafs front and rear. Put on a set of good (Gabrial) nitrogen shocks also. Will ride a little stiffer than stock but not much.Tuffcountry makes good add a leafs.33s should fit no problem.
