re-arching springs
Discussion in 'The Garage' started by 1967k10, Apr 4, 2006.
  1. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    I've got a set of 4" skyjackers on the front of my 67' and I need more room for my 37"s. Would it be easy to have them re-arched to 6" or 7"?
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    It would be easy to do, but may not be worth the effort or money. From what I understand about this by talking to the local spring shop, you will loose the new arch very quickly.
    Also, distance between the spring bushing will decrease and will effect your shackle angle which will hurt the ride quality...
  3. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    yep it doesn't last long
  4. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    x3 waste of money.
    and the more arch you put in the shorter the spring becomes in relation to the stock length. the example 44" eye to eye is stock and thats length of main leaf. the lifted spring will still have 44" eye to eye but longer main leam to cover the arch and diffrent length. so even if you do it there is a point of not going to work as it will pull your shackle in the wrong way.
  5. 1967k10
    Nov 21, 2005
    1,728
    Thanks for the input.I wondered if there was a catch to re-arching.I think I'm going to try to fab up some custom drop front hangers and maybe that will help my pinion angle as well. We did this on my brother truck and it looks like it will work.It's not drivable yet though.
