Re-building NP205
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by dr1553, Sep 10, 2001.
  1. dr1553
    dr1553 Registered Member
    Nov 4, 2000
    90
    Lake Jackson, Texas
    Everyone,
    I finally got my re-build kit. Its full of new bearings, needle bearings, seals, gaskets, more seals and more bearings. It did not come with instructions, bummer. I have a book on 69-72 blazers and it has a short section on the transfer cases but not really detailed with lots of pics. It shows the example(pics and all) of the NP208. It does tell the specs and torques for the NP205.
    Has anyone here re-built their NP205? Is there any special tools that I need before I crack the case open? Any hints and tips?
    Thanks,
    David
  2. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    you'll need:
    sockets:
    1/2
    9/16
    1 1/8
    1 5/16
    you'll also need a big pair of snap ring pliers.
    I think the overhaul manual walks you through the rebuild.
    harry
    69k5
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i second the snap ring pliers. I used the pic on a book. i think it was the chilton manual where i saw it at. do a search on the board. i think someone posted some pics of it.
    actually send me your email address i can send you a copy.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer<P ID="edit"><FONT class="small">Edited by arq on 09/10/01 04:09 PM.</FONT></P>
  4. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I rebuilt mine and the only spec they had was the front and rear output shafts were 150 flbs.
    colin
    Save the whales Harpoon a fat chick.
  5. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    Where did you get your kit, how much did it cost? What brand of bearings came with it? Where made?
  6. dr1553
    Nov 4, 2000
    90
    Lake Jackson, Texas
    Hola,
    I got it at O'Reilly. Item # BCA T172. It cost $150.00 The brand of bearings are Federal Mugul made in USA, the seals are Federal Mogul made in Mexico, and the needle bearings are Federal Mogul made in Brazil.
    Later,
    David
  7. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I got mine from National Drivetrain for $130. It was a Motive Gear kit and included NSK (Japan) and Timken (USA) bearings. I don't recall who made the seals (NOK, I think, which would be Japanese) and couldn't tell about the gaskets. There were a couple of extra bearings in the kit (remember that I had to substitute one of the bearings for a sealed one because of my NV4500) and one or two extra gaskets. One thing I wish they included in the kit would be an assortment of shims for the idler. I didn't need any extra shims (in fact, I needed to delete one), but in case I did it'd have been nice.
  8. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Steve,
    I got the same kit from National Drivetrain... but the one I received did include some shims for the idler shaft. As it turned out though, I too had to pull a shim to set it up and had no need for the ones provided. In my case, (auto trans) I had to purchase one more bearing for the (stock) adapter separately... understandable given it's not really part of the t-case.
    dr1553,
    I burned through two pairs of (inadequate) snap ring pliers before I finally broke down and bought the right pair off the local Snap-On man. Made all the difference. Also, you could do the job without it, but my arbor press came in handy a couple of times. You'll also need a couple of long-nose punches.. I think 1/8" and 1/4" or something like that.
  9. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Make sure you have lots of beer and don't pinch you finger taking the snap rings off, it hurts. That is all I have to offer, sorry.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
  10. Steve_Chin
    Mar 6, 2001
    1,126
    71RestoRod is right about needing the correct pliers. The ones I have are not snap-ring pliers. They are "lock-ring pliers" made by Proto tool (#250G). I seem to always gravitate toward expensive stuff like Proto... Anyhow, you definitely can't pull the lock rings out of an NV4500 with anything less than this tool...
