Re-drilling springs?
Discussion in 'The Garage' started by y5mgisi, Mar 20, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I searched but found nothing regarding the re-drilling of springs. I ask becasue i want to do the 52 swap but dont want to change my wheelbase. Anyone know if this is a posiblity? or is it just a totally bad idea?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    cant redrill springs, weakens them. can run a zero rate to move back 1.5 inches, so wheelbase change is only .5 inch forward.
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Lots of folks have re-drilled their ford 57" rear springs to move the axle back about 1 1/2". I don't think there have been any problems. I donno about front springs, though. Go with a zero-rate to move your axle, like ryan said.
  4. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    So a 1 1/2 inch zero rate is aceptable then? My idea was just to bolt the 52's in the stock location therfore moving the axel BACK 2 inches, so with a 1.5 zero rate would actually push the axel .5 inch rearword. that should work out right?
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I have redrilled several springs never had a problem. but man it sucks drilling springs I mean it really sucks. That said I would do as the others said zero rates or spring relocating deals they make
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I just re-drilled the 56" springs I just installed.
    It was pretty easy with a drill press, cutting oil and some sharp drills.
    I had to sharpen the drill after each hole.
    If I didn't have a drill press, it would have been rough.
  7. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    You'll prolly want to push the axle forward a little to keep your tires out of the firewall. I'd move the front and rear hanger, then use the zero rate to move it back 1.5"
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Well i was tryin to keep quiet about it for fear of beeing flamed... but mabey i just ought to come out with it. I want to do this on my daily driver to get a better ride. I have two shocks at each front wheel, and if i could ook my swayba back up i think i would come up with a smooth, yet stable ride. Thats why i dont wanna change my wheelbase. I dont really care how much flex i have so the firewall wont be an issue. Ive got 4" lift on it now but its almost embarising how bad the ride is. Sooo i figured slap some 52's in there i ought to get a good laid back shackle angle id think? actually now that i think about it it might give me too much of a laid back angle.. i dont know i guess i was just tryin to get the old somthing for nothing.
  9. 85k30
    85k30 Registered Member
    Jan 1, 2003
    24
    re-drilling springs is not really recommended. but if the old centerbolt hole ends up being still between the ubolts it might be ok. if it is outside the u bolt and not being clamped down between the axle tube and the spring plate it could be an accident waiting to happen.
  10. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I'd remove one shock on either side and maybe take a leaf out of the current spring pack. You don't 4 shocks on the front axle, and if you take out the bottom leaf, you should have a less harsh ride.
    For the total cost, you might have a set of center pins and some sweat.
  11. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    go with a set of custom springs. theyll be better than 52's and bolt right in. i have a set of 6" alcans and they are awsome!:D
  12. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Definitely do custom springs (alcans/ deavers) or probably better would be the tough country easy rides. I hear those things ride pretty darn good. Or if you are set on 52's give kert a call at diy4x.com Hes got the front bracket called the b-52, it will allow you to run 52's and leave your axle in stock location. It actually allows you to change to shackle angle too but as a result your axle will change location. I havent put mine on yet because he discovered that the bracket changed a little in the later years and he had already sent me the bracket he made. I can say one thing though is he is great to deal with and he has sent me a new bracket which will be here in a few days. he definitely takes care of his customers.
  13. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Depending on how much you want to go through I think I would just go with the tough country ez rides they do in fact ride great and you bolt them on and go
  14. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    I love my Tuff Country E-Z Rides! 6" front and 4" rear. Everyone always complements the great ride even on Boggers. I highly recomend them.
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    tough country springs are awsome...until you bolt on custom springs. 6" springs softer than 4" tc's. ride better and flex better. they cpst 2x as much but they ARE worth it!
  16. 79k20350
    Nov 22, 2004
    7,757
    Ct
    another thing to try is improve your shackle angle. move your mount forward and run a longer schakle this wil GREATLY improve the ride and is very cheap to do!
