re gear
Discussion in 'The Garage' started by d coenen, Jan 28, 2005.
  1. d coenen
    d coenen Registered Member
    Jan 21, 2005
    76
    bonesteel s.d.
    i have a 79 k5 with 350 35 s automatic trany it has 307 gears not very much power what gears do ineed?. dont know to much about gears so can i find them in a junkyard and how do i tell what they are? i like to go in the mud ,snowand creek crossing with sand under the water thanks.
  2. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    4.56s will work awsome
  3. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    I would suggest at least 4.10's since it would appear you plan to off road it a good deal. If you want better power for off road 4.56 is the best bet imho. if you go to a junkyard you will have to count the ring and pinion gears' teeth. Divide the ring count by the pinion count to get the gear ratio. Example; 41 ring teeth and 11 pinion teeth 41 divide by 11 is 3.73's :waytogo:
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    would also depend on tire height and if you expect it to be any good on highway,
    alot of factors to consider when deciding upon an axle ratio, but 3.07 is horrible,
    personally i think 3.73 without real tall tires is a happy overall useful ratio
    good luck
