Re-Tapering Knuckles from Top?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BDAMNRZ, Jan 26, 2007.
  1. BDAMNRZ
    BDAMNRZ 1/2 ton status
    Aug 9, 2006
    124
    Chesterfield, VA
    If my passenger flat top knuckle TRE comes in from the top, can't I re-taper the drivers side to come in from the top too? If so, shhould the taper be drilled out befor I try to re-taper it? :confused: Any help would be great. I'm new to CK5, but now stranger to wheeling. Looking forward to sharing info! Thanks yall!!!!!!!!!!:waytogo:
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I don't understand what you're asking. Could you re-phrase?
  3. 83 oneton
    83 oneton Registered Member
    Feb 11, 2006
    77
    clackamas oR
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I'm going to say it can't be done. Why not just install an earlier knuckle on the driver side as well.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    if you retaper it from the top you will have half of the depth tapered since the other side will have the other half, it might be enough to hold for a regular size tire but I wouldn't trust it with a big tire.
    If you drill before you taper, you have no more meat to aper.
    If you are going with a bigger TRE from a one ton I heard there is enough meat to do a full taper, but I haven't done it so it's just hear say.
    :D
  6. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    What I'm talking about is re-taper it larger for a GM drag link end. The DL is larger all the way through. If you re-taper from the top for a draglink, there should be enough material left inside the hole to take away. I will you informed. I'm still waiting for my tapered reamer to arrive.
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    SO I guess I had all the right info.
    :D
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    why not weld it shut first?
  9. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    That's fine too.
  10. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    AFAIK, all Chevy 4x4 had the 1 ton TRE's.
  11. 1977k5
    May 26, 2003
    9,992
    130
    Is the rod as hard as the steering arm? How do you know you didn't leave any gaps where you filled the whole?
    This whole thing (no pun intended) sounds like a bad idea to me.
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I've done it a few times, wheeled the hell out of em including a friends running full hydro with way more umph than was necessary, Pushed the knuckle in half and the tapered hole was still pristeen. No worries.
    EDIT: as far as gaps are concerned, the right technique is required. When you drill the pilot hole, you'll know.
  13. BDAMNRZ
    Aug 9, 2006
    124
    Chesterfield, VA
    I found a match for my flat top. Now I can do it right and quit brainstorming! Thanks everybody.
