Re-use Harmonic Balancer? (305 to 350)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric, Dec 26, 2000.
  1. Eric
    Eric Registered Member
    Mar 21, 2000
    86
    Do I need to buy a new harmonic balancer when changing from my stock 305 to a crate 350 and if so, what size do I get?
    Can I re-use my flexplate?
    One eyed super fly- watch out!
    86 K5 Blazer
  2. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    No, you need to get a balancer for a 350. The one from your 305 is much smaller.
    bart
  3. Eric
    Mar 21, 2000
    86
    Found a flexplate at Summit Racing with 168 teeth and marked for pre-1986 vehicals with 2 piece rear main seal. Is this the correct one for my 350 crate motor (71-85), just want to make sure?
    How about that harmonic balancer, anyone else have some suggestions.
    Thanks alot!!
    86 K5 Blazer
  4. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I'd go with the new balancer too. Sounds like the right flexplate.
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    When I swapped over I got a boneyard (looked good) bal off a 70's vintage GM 350. The 305 ones that come with the K5's suck 'cause of the timing pickup on the top of the timing chain cover. A standard timing marker wont line up with this kind of balancer. I got a flexplate for a 87 chevy PU (for 1 pc rear main) at autozone. Just check your toothcount and look for the different hub size and weights, about $45.
    <P ID="edit"><FONT SIZE=-1>Edited by Cavalry on 12/27/00 08:41 PM (server time).</FONT></P>
