RE: What did the factory put on these floor boards
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mlb79, May 6, 2002.
  1. mlb79
    mlb79 Registered Member
    May 24, 2001
    40
    evansville, IN
    I am trying to clean up what's left of my floor boards so I can rust proof (corroless) and put in some sheet metal overlays. I am having trouble getting the floors clean, there is something like contact paper on the floor boards on both sides. It covers the entire floor pan. The factory paint is on top and unless this sticky stuff is pulling the paint up, there is virgin metal under it.
    Anybody ever run into this? I am having trouble getting it off the metal, any suggestions on how to remove it without a die grinder, I thought maybe a heat gun, any suggestions?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I tried every chemical and paint scraper out there but I ended up using a wire wheel to get that $h!t off. It was quite a mess but it worked fast.
  3. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Yep... I did the wire wheel too.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    wire wheel.....
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I believe the wire wheels have it. I wonder what the brain trust at GM was thinking on that. Mine wasn't glued fully and a few gaps and water got underneath it and I had a nice little rot spot. Apparently galvanized was to just too hard in the early days /forums/images/icons/tongue.gif. I believe in the early 80's they went to galvanized on some things. My '82 Blazer has that rubber, but an '85 'burb i use for parts have a galvanized pan, which is rust free, unlike the rest of it.
  6. mlb79
    May 24, 2001
    40
    evansville, IN
    Thanks for the replies! Although I had hoped for a magic potion to strip that garbage off. Sounds unanomous for the wire wheel. I wish I could find adhesive that strong for other applications.
    I really would like to know what was on GM's mind when they pulled this one. The wife asked me why there was contact paper on the floor in my truck. Contact paper is for Kitchens!!
  7. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I would think it is most likely a heat and vibration barrier. Keeps the rattles down. I too used a wire wheel, it smells nice when you hit the body caulk with it!!!! and it makes some nice smoke too!! Make sure you wear safety goggles, it will spit crap everywhere!! - Doug
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    a tip from when i did mine: keep the wire wheel spinning so the stuff that is coming off the wheel well is shooting out the back of the blazer, if you do it the other way around you will be finding blaxk stuff for a long while.
  9. Qubit
    Qubit Registered Member
    Mar 29, 2002
    21
    Redwood City, CA
    I successfully did it with a heat gun.
    It came off fairly easily.
