Real basic question: TBI fuel pressure gauge
Discussion in 'The Garage' started by Mastiff, Jun 30, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I got a fuel pressure gauge to check the pressure at the inlet on my TBI. I have an adapter to fit the AN-6 line, and the gauge fits into the adapter with a smaller tapered pipe thread. My question: Should I put some thread tape or sealer on this pipe thread? Is there a special kind for this application where it'll be exposed to gas?
    The gauge (I got the 0-30 PSI version):
    The adapter:
  2. nvrenuf
    Jan 7, 2002
    13,081
    248
    Mobile, Al.
    All of the throttle bodies I've seen have either o-ring or flared type fittings, for these no sealant is needed because the threads are not exposed to the fuel.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'd put PTFE tape or similar on the guage threads. The others, as has been said, should seal be o ring or taper seat fitting as opposed to a taper thread like the gauge.. /forums/images/graemlins/thumb.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    NEVER use teflon tape on your fuel system. If you ever take it apart again, the little bits of shredded tape then have a shot at clogging up your fuel injectors. /forums/images/graemlins/frown.gif Thread sealants are for use with pipe threads. A compression fitting doesn't need it (and it won't help even if you use it). /forums/images/graemlins/eek.gif
    Did you get a fuel pressure gauge isolator with your setup? It mounts inline with the fuel line to the gauge and prevents fuel from entering the passenger compartment. You do NOT want a pressurized gas line inside the cabin. /forums/images/graemlins/yikes.gif
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if your gauge is like mine, it is regular pipe threads, yes its dumb that its not a flare, but on the threads of the gauge, you need sealer, i didnt and mine leaked, sealer and dont leak. Yes you will need a sealer that can come in contact w/ gasoline. The makes of loc-tite have one. Go to Autozone(or somewhere) and go to loctite area, its a white tube same size as loctite tubes, and i THINK the number is 567 but i am not sure, just read the package. The actual tube doesnt say oil/gasoline safe, but the package does.
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks for the info. I'll look for the loctite stuff.
    I'm planning to just leave the gauge under the hood near the throttle body for troubleshooting or whatever, I'm not running it into the passenger compartment. The isolators look like the slick ticket for routing it inside though.
