Real differences between 2500's vs 3500
Discussion in 'Tow & Trailer' started by Pookster, Jul 29, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Real differences between 2500\'s vs 3500
    Trying to find the acutal differences between the two, but so far, Im comming up with not too much.
    Cab/frame/body= seems the same from what I could find.
    Brakes= I believe the 3500 had bigger brakes-But I cant seem to find if they are different on the front. Rear brakes are only different if it was a 14bSF vs 14bFF and dually drum brakes were bigger.
    Engine- The engine/tranny combo's looked identical between the two. No special choices for one vs the other.
    Tire Size: I think the 3500's got 245 standard, and the 2500's were getting something slightly smaller standard.
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Re: Real differences between 2500\'s vs 3500
    All of these replies are IIRC, so don't quote me /forums/images/graemlins/waytogo.gif
    I believe the 3500's got a heavier grade steel for the frames VS the 2500's
    The 3500's did get bigger front pads and rotors.
    The 3500's obviusly have a higher trailer weight rating, 10,500 for 3500's vs an average of 8000 for 2500's depending on engine and gearing.
    I hope this helps some /forums/images/graemlins/waytogo.gif
    Krennen
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Most of the time the true 1tons will get those auxilary rear overload srpings. YOu know the type that ride on top of the normal spring and hit the frame brackets once the truck is loaded up. I could be wrong though...
    Blake
  4. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    thats what Im wondering- the C/K series of pickups had minimal frame differences between the 2500/3500- I didnt take a micrometer or anything, but it looks as if the frames are identical.
    Was just hoping someone had some real specs somewhere!
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    You really need to specify what range of years you are talking about. The differences between the two models vary whether you are talking about the '87-older, '88-'98, or current generation trucks.
  6. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,040
    1,108
    Dallas
    Interesting tid-bit:
    The '91-'99 3/4 ton suburbans had a "snow plow" option with gave them 1 ton torsion bars as well as 1 ton brakes front and rear. With that option came another - dual alternators.
    I have only ever heard of two such suburbans; both were diesels.
  7. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I thought that the 3500 has a taller frame.
  8. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    88-98 is the specific years Im questioning.
    dual alternators would be sweeeeet. /forums/images/graemlins/smile.gif Any way to retrofit that into my truck?
  9. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I won't guarantee everything below is accurate, but it's based on what I have actually seen or have heard from reliable sources....
    Starting in '88 Chevy had a "light-duty" 2500 that was basically a 1500 with the exception of the 14SF rear axle and probably some heavier springs. These are easily recognized by the 6-lug wheels. I also believe the 350 (5.7L) or 6.5L TD were the biggest engines available. For transmissions I think the 4L60 (700r4) was common, not sure if the 4L80E was available or not. I also believe that there were only 6-lug 2500 trucks available for at least a year two.
    The "heavy-duty" 2500 had 8-lug wheels and still used, at least most of the ones I have seen, the 14SF rear axle, however the front axle and suspension was bigger (I believe it's the 9.25" IFS diff??). The springs were heavier but I'm not sure if the frame was any different. I also believe the 454 was available and the autos were 4L80Es.
    For the 3500 SRW, the only noticable difference I have seen was the 14FF rear axle. Engines, transmissions, front axle, etc...all appeared to be the same. It did appear to have heavier rear springs.
  10. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I have a little to add:
    The 6.5 trucks came with 4L80 transmissions. The 2500LD was available until 93-94.
    9.5" SF rear came in small block 2500HD trucks only, 14FF came with 7.4 and 6.5 trucks.
    14FF used in single wheel trucks and small block dual wheel with wider drums, D70 in 7.4 and 6.5 dual wheel.
    That sums up my limited knowledge. Might be wrong, though./forums/images/graemlins/thumb.gif
  11. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    My 3500 SRW does not have the aux. overload spring on top of the standard spring pack. Has tow package from factory.
    From what I recall the 245 was the standard tire on 2500/3500s. The 1500s had the shorter 225s.
    When I worked at the dealer I seen a '90 reg cab 3500 IFS truck with SRW. It was outfitted with 454/TH400 and D70 SRW.
    Only one I have ever seen.
  12. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ok, aside from the LD 2500, the regular 2500 and the 3500's only real difference is the... possibility of a stiffer spring, and a 14b/D70 axle?
    Are the front brakes the same as well on the SRW models?
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    As was stated above, frame differences are taller section and thicker guage, not visible by the naked eye but still stronger.
