Real quick question:
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91gmcjimmyCH_IL, Apr 15, 2002.
  1. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    How do you seperate the two halves on a driveshaft. the kind that has splines. is this called a slip shaft? I have to take my tom woods driveshaft apart and I have no idea what is involved. Thanks
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Remove the clips holding the cups in and then take a press and press the cups out, or take an old socket and a hammer and hammer them out. I'm assuming your not going to reuse the ujoint? If you are then just be very careful.
  3. 91gmcjimmyCH_IL
    May 24, 2001
    110
    Grayslake, IL
    I don't need to take the u-joints out, I want to know how to pull the two halves of the driveshaft apart. the kind of driveshaft I have has splines that the shaft slips on to expand and contract. this is located near the pinion. OK, this will let you know what kind of driveshaft I have; I have a fixed output on the transfer case. How do you pull them apart?
  4. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    First make an alignment mark on the shaft so when you sepperate it, you can re-assemble it with the splines matched up again (very important for balance). There is either a screw on or crimp on cap on the compression yolk side of the shaft which is a seal to keep contaminants out and grease in which is smaller than the splines on the main shaft. You'll have to screw or slide this off the yolk at which point the it will just slide off the shaft leaving the seal there.
  5. 91gmcjimmyCH_IL
    May 24, 2001
    110
    Grayslake, IL
    Thank you very much.
