really anoying problem..brake lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz88K5, Mar 3, 2002.
  1. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    Ok this prob has been goin on for about 6 months now and i just cant seem to finger it out....well the problem is that my brake lights keep burnin out within about 2 weeks after i instal them...the running lights are fine but it just the one filliment in the bulb that keeps blowin...i have tried LED bulbs and they lasted a week longer but dident solve my problem...anyone have any ideas for me on what to look for...i am not a wireing type of person so this crap gets on my nerves
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Probably the wire is grounding out somewhere...You need to follow that wire.. And check for cracks in the wire where it can short out....Good luck...Dan
  3. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Had the same problem with a set of Cepek lights. Kept burning out the damn bulbs. Traced it down to a bad ground, it some how was giving the lights a voltage spike. Check your grounds Dude,I would almost bet money thats your problem. I said almost bet money
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    A short in your wires or a relay. Just a thought.
  5. Chaz88K5
    2,979
    Stockton/Lodi CA
    there are relays on tail lights??...not from what i have seen..this is another think that i have noticed...i dont know if it changes anything or not..but the driver side always burns out first...then the passenger a few days later...prob still something to do with a ground eh...would no ground strap from the motor to the fire wall make a difference?...i just noticed that today that it broke...how i have no clue...but it is no longer connected....damn i hate wiring!!!
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I think the wires come along the drivers side..Then go over to the passenger side.. That would make since that that one goes out first.. So the problem probably between there and up to the front.. As for the grounding strap... That would cause all your lights to go out if that was the problem.. But you should hook it back up...Dan
  7. Chaz88K5
    2,979
    Stockton/Lodi CA
    welp looks like i have a project tommorow after noon to add to the many others that have been building...i am not lookin forward to this at all...anyone willing to do it for me haha
  8. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    It could be a short between the seat and the steering wheel. ah i'm just kidin'
  9. Chaz88K5
    2,979
    Stockton/Lodi CA
    alright smart ass....good one /forums/images/icons/laugh.gif
  10. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Chaz... one quick tid-bit I have found is that alot of these trucks suffer breaks, pinches, and other wiring woes where the wires go above the fuel tank. It is a PIA to check but you should be able to see some above the tank with a flashlight, or else I have rewired from right under the driver's seat area all the way back for the tailights before just because a high quality wiring repair is still easier then dealing with the tank. Just an extra two bits. Good luck.
  11. Chaz88K5
    2,979
    Stockton/Lodi CA
    sounds like a plan for next weekend...got alot of work on my hands it sounds like
