REALLY Big Block
Discussion in 'The Garage' started by TSGB, May 11, 2004.
  1. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I figure if there's a place to ask it, it's here.
    What is the biggest IC Engine in the world, and what's it in???
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Probably one of those big ass engines in a ship....like those pics floating around of the Japanese ship engine...
  3. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    big engine
    This could be it. /forums/images/graemlins/dunno.gif
  4. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Yeah, that's the one I was talkin bout! /forums/images/graemlins/waytogo.gif
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    For some reason I think I remember seeing a much larger 12 cyl version of that /forums/images/graemlins/thinking.gif
  6. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    What type of engine is on that crawler NASA uses to move the space shuttles around???
  7. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    you know you have a big block when there are stairs to get down inside your cam /forums/images/graemlins/eek.gif /forums/images/graemlins/histerical.gif
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Well that is huge motor, but I always like the chance to bag a little /forums/images/graemlins/whistling.gif
    I worked at Cat LEC for a little while. When I was there we put together 6 gensets, tandems. So one motor runs forward and the other backward, both are mounted to a gnerator in the middle. These are 12cyl turbo desiel motors. The bases where right about 22 feet. I designed the bases, cool lines, part of the wiring, and safty equipment. Each genset sold for $1million (x6). They where for a Finland Cruiseliner.
  9. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Z3PR would probably know, he knows a lot!
  10. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    the pictures of that motor show a 10 cylinder version, They make a 14 cyl version of the same, Rated at I believe 102,000 H.P, like 5,000,000 ft Lbs. of torque. they use them on container ships. I read that the solid rocket boosters on the space shuttle are the highest rated prime mover in the world they produce thrust that is equal to 10,000,000 horsepower /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    HOLY [DARN] thats alot of ponies /forums/images/graemlins/bow.gif
  12. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    Of course due to the design on them, they can't be shut
    off till they run out of fuel... Imagine that in your truck
    /forums/images/graemlins/yikes.gif
  13. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Talk about a gas hawg!!! /forums/images/graemlins/histerical.gif
    Even at its most efficient power setting, the Sulzer 12 cylinder consumes nearly 1,660 gallons of heavy fuel oil an hour.
  14. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    needs headers
