Really dumb 4x4 Q?
Discussion in 'The Garage' started by sho_shane, Jan 20, 2007.
  1. sho_shane
    sho_shane Registered Member
    Dec 27, 2006
    51
    Leonard Tx
    Ok here it is, Please dont make fun of me.
    I have a NP203 in my truck. I dont know jack about 4x4 truck and im just now starting to learn. So im reading and reading. What im having a prob with is, I hear you guys talking about full time and part time. I really have no clue what yall are talking about. It there a link out there somewhere that will have all I need to know about 4x4's and transfer cases? Like I was told that I have a NP203 and that its full time. But that its probly been swaped to part time:confused: Ok now that just messes me up. I ave no clue what that means? Or what is better? So someone hook me up with a link or some info on this. Thanks for any and all help.
  2. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    http://www.4x4mecca.com/forum/showthread.php?t=221
    Try reading some of that. With the 203 Full Time you are always in 4 wheel drive, converting it to part time allows you to take it out of 4 wheel drive. Frees up gas mileage a little and is easier to turn the front wheels.
    Someone else jump in if im wrong.
  3. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    It's definitely best to have a part-time equipped NP203; if not you have a full-time four wheel drive, which bites you at the fuel pump. Here are the Mile Marker part-time conversion kits: http://www.milemarker.com/4x2conversion.html
    I don't remember how to tell if you already have a part-time kit installed, but a forum search will return your answer. See, no one made fun of you... yet.
  4. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Full time also puts unnecessary wear on parts that otherwise wouldn't be turning, like u-joints.
  5. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    I have locking and unlocking hubs. Does that mean that I have part time?
  6. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    Just put in Hi and unlock the hubs. If the truck moves you got a part time conversion. If you have full time 4wd you have to have it in HiLoc with unlocked hubs.
  7. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    cool ill check that.
  8. sho_shane
    Dec 27, 2006
    51
    Leonard Tx
    Ok that is put it in 4x4 hi right?
  9. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Yea, that´s what I meant, the test works in 4wd Lo too. If you have a full time 4wd NP203 the center differential in it causes all the power to go to the unlocked frontwheels and the truck doesn´t move until you put it in 4wd Hi/Low Loc and lock the center differential. A stock full time 4wd doesn´t have freewheeling hubs so yours is probably converted to part time.
  10. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    Yeah you can also just look under it and see if the fornt driveshaft is spinning while the trucks moving but it sounds like its partime
  11. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    That could be pretty hard to do bu yourself though:D
