really high oil pressure, need help
Discussion in 'The Garage' started by milspecjimmy, Feb 23, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i just put a salvage yard motor from a 1987 G20 van in my jimmy. it at some point had been rebuilt. it is completely installed, and runs very well. the only problem is that the oil pressure gauge(factory) shows 60 lbs of oil pressure at idle, and goes off the scale when you rev it at all. I figured that since the motor had sat around the salvage yard for a while it may have had a stuck pressure relief valve in the oil pump, so i bought a new melling pump and installed it today. No change in pressure readings. could it be the gauge? i used the sending unit from the motor that was originaly in the jimmy. HELP
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Try a machanical gauge. I really never trusted the electrical gauges. You may wanta flush the oiling system.
  3. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    i did flush the oil system. i put 3 cups of keroseen in the oil, and ran it for 15~20 min at idle, and noticed no change in the pressure. then i changed teh pump and oil/oil filter
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Sounds like a restriction somewhere...not good.
    I'm not sure what to do about it though.
    Did you pull any main or rod bearing caps to check for wear?
    -- Mike
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    -- Mike
  6. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    the sick thing is that i just sold my mechanical gauge to REDFROG /forums/images/graemlins/rolleyes.gif
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I'm pretty sure I have an extra stock mechanical oil pressure gauge in my garage.
    You have to buy the universal mech gauge hose kit at Autozone or whatever you have around you to connect it since I don't have a spare hard line (plus how would one ship that sort of thing?)
    -- Mike
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Did your origional Jimmy engine have an oil cooler and now you don't? I had the exact same problem on my engine after just removing the factory oil cooler. I had 45 pounds at idle and pegged the guage when I hit the gas. Drove it like that with no problems untill I parked it a couple months later.
  9. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Mine has stayed peged while I drive since I got the new motor, It Idles at 30. Not that that helps you any /forums/images/graemlins/confused.gif
  10. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    i am thinking the oil pressure switch, or the gauge is screwed up. i am going to put a hand held gauge on it monday and see what is says.
