Really stiff brakes
Discussion in 'The Garage' started by Calclips, Jun 4, 2003.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've got an 82 K20 on 35" Hawgs, and the brakes on it are really really stiff. I have to stand on the pedal to get it to stop. The truck has a new master cylinder in it, what are a few things I should check out this weekend when I'm home from school?
    Thanks,
    Dan
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Sounds like the booster is bad. Or a vacuum line going to it is missing or disconnected. This will cause stiff brakes.
    John
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Ooooh ooooh oooooh......I know this one!!! /forums/images/graemlins/grin.gif
    It could be a few things, but if a previous owner (let's call him numbnutz!) used a fuel line to run from the manifold up to the vaccuum port on the booster.....odds are good that it's collapsed by now and you are getting ZERO vaccuum assist!!! Happened to me!!!!
    Vaccuum Hose is special, and much more resistant to being sucked shut. Check the markings on the hose....if you're not sure, replace it with the REAL stuff. It's one of the cheapest things you can do to start troubleshooting your problem anyway.......
  4. Calclips
    Apr 4, 2001
    1,005
    forgot I had this post laying around out there... I'll check and see if numbnutz did anything of the sort. If the vac line is not hooked up do I just hook it to a vac port on the manifold, or one of the ones off of the carb?
