Reaming a Pitman arm?
Discussion in 'The Garage' started by PsychoticDeadGuy, Mar 23, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I have a pitman arm that I need to ream out for a 1-ton GM TRE. What is the taper and what depth do I go?
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    The taper is 1.5" per foot and you need to have the TRE in hand while you are reaming. You can either measure the TRE with a caliper and transfer and mark this measurement on the reamer or you can just ream the arm a little at a time and test fit until you get it right.
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Yep, snap-on r121 is a 7* taper. It's what I used. Keep trying the tre until it fits right. If you get the snap-on reamer, use a heavy feed, and cutting oil. The snap-on reamer seemed like a POS when I got it, didn't seem sharp at all. I'm used to having to handle reamers very carefully, so you dont slice yourself open. I read on pirate to use a heavy feed with it, thats what I did and it worked perfectly.
