Reaming D44 knuckle for tierod to go in through the bottom??
Discussion in 'The Garage' started by 85mudblazin, Jul 14, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Would I run into a problem if I tried to ream out a D44 knuckle so that the tie rod goes in through the bottom like 10b's?? Maybe not make a tight fit since the top would still be big :confused:
    -Chris
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I wouldn't do it. Not enough contact area in the knuckle on the TRE if it was only tapered 1/2 way.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thats what I was kind of thinking. Guess zero rates it is :D
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    There was some guy on pirate that made some tapered sleeves that he would put in with loctite sleeve retainer. He would then taper it from the other side. The other option you have is to get TRE's like come on 1st gens because they have a drop down built into them.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I was going to do this but with drag link ends instead which have the same taper but are larger in diameter. I didn't want to buy the reamer so I cut off some overloads to use as "zero rates".
  6. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    i just read the writeup on here about the d44 crossover swap, and he reamed the d44 knuckle to go fromt he bottom
