reap wiper on 94 blazer problem/air dam
Discussion in '1992-Present Chevy & GMC models' started by hoppy, Nov 21, 2002.
  1. hoppy
    hoppy Registered Member
    Aug 20, 2002
    this is a minor problem but my rear wiper wont clean all my misses almost 1/2 of the upper window. i noticed the arm seemed stiff so i worked it back and forth and it loosened alittle. it seems the spring in side to give it the tension on the window is no good. could that be it? also....the arm could use some do you remove it?
    another question i have is....can you get an after market air dam that looks like the original with the hook cutouts but also with light holes? if i decided to cut the one i had for lights how would i go about mounting them in the cutouts?
