Reaper - Timing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Jun 13, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Reaper:
    I see the bolt on the water pump - do you think it might also work if I put the balancer on and just create a white line on the balancer where the "zero" mark is on the teeth? That would give the the ability to advance or retard.
    Chris
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    That's a good idea!!
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  3. Grim-Reaper
    7,385
    Atlanta
    Yeah it works fine. That's what I did. Turned it till it was TDC to the old mark on the other engine Sighted down the bolts on the back of the water pump and made a mark. I advanced it till I got ping and backed it off about 2 deg. Ended up being at 10 deg of advance so I got it atleast withing about 2 deg of right with my eye (that amazed me cause I'm about a cross eyed fool). Set it 2 years ago and haven't touched it. As long as my wife puts in 89 we haven't had a problem.
    If you want to get real fancy you could figure out the deg change between the timming tabs and put a mark on the ballancer that will work with the new style cover and be acurate. To be dead on 100% right find somebody with a degree wheel and you can figure out true TDC and again mark the ballancer.
    It's not my damn planet monkey boy!
    Grim-Reaper
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Whoa! How'd we suddenly get to a different thread? [​IMG] I just posted this as a way to set your timing in the other timing-related thread that you have going. [​IMG]
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
