Rear 10 Bolt Axle for a 90' Suburban
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82K5_6.5L, Jan 12, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    Rear 10 Bolt Axle for a 90\' Suburban
    my friend blew the gears in his rear diff. of his 1990 Suburban doing a nuetral drop (which is dumb to do) should he replace the gears on it or get a new axle???
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: Rear 10 Bolt Axle for a 90\' Suburban
    More info on the truck please. /forums/images/graemlins/deal.gif
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    IMO, a Suburban should never have come with a 8.5" rear axle. Time for 8-lug /forums/images/graemlins/thumb.gif
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    that's what I'm saying! not ragging on ya either, we have an 89 sub with 10 bolts /forums/images/graemlins/burb.gif, i don't trust those axles farther than i can throw them on something that heavy, especially if it will see any offroad use or abuse. I usually try not to tell everyone to put a 14bolt in thier truck, but this will be an exception, find out what gear ratio the truck currently has and try to find a 14ff with gears to match. you will need to get 8 lug outers for the front axle and buy new wheels and if you want to run 15'' wheels you will need to grind the front calipers.....OR, PM TONYP, he makes adapters to make the 14ff 6 lug so that you can use your existing wheels /forums/images/graemlins/thumb.gif.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    although the 8.5" always seem to have held up under the late 70;s vans, so hmm.. i never have had a problem with any 8.5" cept til 88 came around, its always the 12 bolts that loose ring gears and yokes
    good luck
  6. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    well i agree go to a stronger rear end mabe even just a step up to the semi floater ?? and then get the 6 lug axles for it or the adapters from tony p that way its a fairly cheep easy quick fix for ya /forums/images/graemlins/burb.gif
  7. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    If you decide to go with keeping the 10 bold I have one with 3.73 gears in it. It came out of my 89 Burb in November when I switched to a 14 bolt. Send me an email if interested(it's cheap).
