Rear 10 Bolt Axle Seal
Discussion in 'The Garage' started by daleearnhardt01, Aug 27, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Need to replace them on both sides. How hard is it to do? Does the backing plate need to come off? What tools do you suggest. Thanks /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    They're not hard to do. But while you're doing them, it would be a safe bet to replace your rear wheel bearings. They can be tricky without a slide hammer... But you can rent one at your local auto zone.. You need to pull the diff cover and the cross pin in the diff, then slide your axles in and remove the c-clips. Once they're out you can pull the axles. The backing plates stay on... The seal is in the end of the axle tube and the bearing is right behind it....
    /forums/images/graemlins/thumb.gif
