Rear 10b locker work in front 10b??
Discussion in 'The Garage' started by 85mudblazin, Mar 23, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I know the ring gears and carrier are the same size but I never see the 10b lockers listed as front or rear, I know the rear has C-clips so im notsure how the locker would work. But I need to know if the rear 10b locker will work up front.
    -Chris
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    yep, works in either end. only difference is you dont use the c clips.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    SWEET, thanks :)
  4. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Yeah, if they are both 30 spline axles! Most 10 b fronts other than post 89 are 28 spline. Know what you have before you start.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    was the rear ever changed?? I thought it was 28 spline just like the older 10b fronts.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There are 30 spline rear axles too but they didn't start till 89 either. So if you have a 28 spline front then you probably have a 28 spline rear too.
    Harley
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    well crud, I found a guy that has 2 to bolts that have lockrites and detroit ez lockers in them but they are 30 spline since his truck is a 90', so it looks like ill be getting his axle shafts also :) The only thing I dont like about that is it might be harder to find 30 spline axles since they were only made for a few years. I guess if I cant find a spare axle I can just carry my 28 spline stuff and if I break one then I will just have to wheel open on 28 spline.
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Or you can buy my 30 spline Moser axles brand new still in the box for $200 plus shipping. :p:
  9. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Or you can buy my entire 10b front assembly as a spare :D
  10. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    This is the situation I'm in also. I'm having a hard time finding spare 30 front shafts.
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Ok I'm not even joking anymore. I have an '89 and a 10b front so if someone wants the shafts PM me and when I remove the shafts I'll make sure they're 30 spline and send 'em out.
