Rear 2 piece drive shaft question
Discussion in 'The Garage' started by stoney126, Jul 17, 2006.
  1. stoney126
    stoney126 1/2 ton status
    Jun 2, 2005
    1,458
    napa,CA
    Hey all In the process of lifting my crewcab and it has a 2 piece rear driveshaft. My question is do I take both pieces to get lengthened or just 1 piece and which one?
  2. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    How much are you lifting it? If your not going too high Im sure you can get away with just that little drop spacer that goes in between the carrier bearing and the frame. Otherwise from the looks of when I lifted my crew cab (I didnt need to lengthen the driveshafts) but it looked as though just the rear part of the shaft would need to be lengthened. Im sure someone here will be able to definitively answer that.
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Unless you are moving the T case, I don't see how the distance between the back of the T case and the carrier bearing is going to change. They are both bolted to the frame, not to a movable part of the suspension.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Second this. Put a spacer between the frame and carrier bearing. Its cheaper and easier to do.
  5. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    It' ane 8 inch lift can i still get away with a spacer?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, especially on a long wheelbase you can.
  7. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    sweet, nothing like saving a lil moola to uncrapify a day :D
  8. stoney126
    Jun 2, 2005
    1,458
    napa,CA
    what should i use some washers? And what size do ya think would work?
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, no, don't use washers. Stay away from washers especially on something crucial like driveline related parts.
    Use solid stock and drill holes thru them in the thickness you need. I'd get some hollow tubing and determine how thick you need to space it down and then when you are satisfied, get some solid stock and drill the holes out. Using solid stock will give you a peace of mind knowing you have something bulletproof under there.
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I have 12" leafs (or supposed to be) and my stock 2 piece shaft worked fine... dropped the carrier bearing a few inches using square tubing.. drilled holes and used longer bolts...... works fine...
    however I have some wobbleing from time to time.. if I launch hard enough I can get the rear tires to hop off the ground.. you should see peoples faces!!! :haha:
