Rear 9012 and exhaust setup pictures
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Oct 23, 2000.
  1. CK5
    May 19, 1999
    21,627
    704
    CO
    Hey guys
    Just got the UAV back from Offroad Ltd. in Aurora CO, they mounted my rear RS 9012 and did my custom exhaust (cut off when I installed my ORD flip). All I can say is, it sure is nice to have something done and find out they did a better job than what I was expecting. They ran my 3" exhaust along the frame and used the old shock mount for a new exhaust mount. The mounts at the top are on a tube that are right up tight against the body but do not touch. The bottom shock mounts are on the back of the axle and sit flush with the bottom of the axle so they wont get hit off-road. Can't wait to install my Ford shock towers and test the articulation. Sorry about the pics, it was dark out when I got home today.
    http://www.coloradok5.com/ranchoshockreview
    5,000 Pounds of American Rolling Steel
  2. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    cool, i want some.
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  3. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
  4. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
  5. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
  6. CK5
    May 19, 1999
    21,627
    704
    CO
    You know, you can just edit your first post, just click on the edit button. [​IMG]
    The upper shock tube is welded to the frame, I was going to have them bolt it in, but they would have to sleeve it to get it in between the frame rails and I did not want to go that route.
  7. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Steve,
    Can you give me dimensions on that shock mount? Is that a bolt on peice?
    Neil
    Mudzer 1978/91 K5
    <font color=blue>www.mudzer.coloradoK5.com</font color=blue>
  8. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Looks great!!!!! Is the bar that the top of the shocks mount to attached to the frame rails?? Is it bolted or welded?
    Ok by the time I posted you already answered. You should get some good stuff and droop with that setup!!!!!
  9. mybeast
    mybeast Registered Member
    Oct 10, 2000
    95
    Simi Valley, Ca.
    Shawn,
    Is the 9012 shock just a long travel shock. How did you figure out were to mount the bottom, or is that the org.location just moved it to the axle?Ok one more question is the bracket at the top custom , or is that something you bought?
    When all else fails MASH the skinny pedal!
  10. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    Hey, is that the ORD 1inch saggy butt fix on there? Or is that your fix till you get one?
    Looks awesome though, that is exactly how I wanted to run one side of my exhaust too. Now I know it works great.
    Go heavy or Go home[​IMG]
  11. CK5
    May 19, 1999
    21,627
    704
    CO
    The top bar that holds the shocks is welded to the frame.
    Yes, that is the ORD saggy butt fix add-a-leaf works like a block thingee.
    The 9012 is the longest adjustable shock Rancho makes, the shocks on the bottom mount flush with the axle.
    The top bar as well as the new bottom brackets were custom made by Offroad Ltd. a 4x4 shop here in Colorado.
    Neil, what measurements do you need? The bar at the top is real close to the body and the bottom mounts are close to the spring hangers.
    Oh yeah, my name is Steve not Shawn. [​IMG]
  12. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    SWWWEEETTT, StevO yer KIllin ME!![​IMG]
    I can't keep up with you!!
    You a Dep are an Insparation for me and my rig!!
    I Must get this done to my rear also!! My shocks are so low on my axel its scarry[​IMG]
    Any hoo I like the tube idea for the top 'hoop' Groovy stuff!!![​IMG]
    OK more coffeeeeeeeeeeeeeee[​IMG]
    http://www.burt4x4.coloradok5.com
  13. Mudzer
    3,639
    Missouri
    Steve (Shawn) [​IMG][​IMG]
    I was wondering how far apart the shocks are at the top, plus how far apart at the bottom. I wanted to figure the angle so I can Copy Cat your idea! [​IMG] Maybe I will make a bunch and start selling them as a kit. Just kidding.
    Mudzer 1978/91 K5
  14. Burt4x4
    6,854
    Hey StevO, I was lookin at it again and just dawned on me that you put both shocks to the back instead of on the inside!! Why, does it make a diff as to witch side of the rear you mount too????? I belive DepDog was on the inside, yes no maby so?????
  15. CK5
    May 19, 1999
    21,627
    704
    CO
    Neil, I will measure for ya, but keep in mind I have a 5" lift now so on yours it may be different. As far as a kit goes it would be better to just have it done locally because I am finding out that no two K5's are the same, you would end up having 9 out of ten sent back to be lengthend or shortened thus removing any profit - not worth the hassle.
  16. CK5
    May 19, 1999
    21,627
    704
    CO
    Burt
    By being on the back of the axle there is less chance of them being hit on a rock while off-roading, I figure you drive forward more than you drive in reverse.
  17. Burt4x4
    6,854
    Ya thats what I figured you were doing. Just wanted to know if there were any other thoughts behind putting them in the front versus the back.Axel movement, exceleration and twist stuff like that????
  18. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
    I hate to be a "copy cat", but I'm ALL OVER that shock mount set-up. [​IMG] Looks great Steve!!!
    <font color=red>~BigBurban</font color=red>
    http://www.geocities.com/crash607
  19. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Mine are in the front because it was a little to close to my gas tank to be in the rear. Never smacked em on a rock yet (damn, should not have said that) I dont think they effect on axle wrap would change any from putting them on the front or rear.
    Min have been on for over a year and a half like this and 0 problems. Steve to keep them off the rocks even more you need to turn them upside down. If you do the remote kit with them the way you have them you have to leave a large loop of the air hose hanging down for shock travel. Not a good idea on the trail.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  20. CK5
    May 19, 1999
    21,627
    704
    CO
    I kind of like the idea of mounting the shocks the way they were designed to be installed, I will run the remote and see if I have any problems off-road, I think they will be OK because they are on the back side and a line to the shocks are not a "show stopper" for me getting off the trail anyway. As far as the loop for wheel travel goes, I will put that at the top of the shock, but if I run into problems I can always flip them and try that, Damn, that means that I have to go out and test some more. [​IMG]
