Rear air noise
Discussion in '1936-Present Suburban' started by fireinthehole, Jul 29, 2003.
    When I turn on my rear air, the fan makes a lot of noise. Does anybody else's do this? If so did you fix it?
    Also, my ac isnt that cold, which probably needs charged and its R12. I hate to see how much that costs /forums/images/graemlins/frown.gif
    Mat
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Noisy fan usually means either the fins on the fan are broken/breaking, or the motor bearing/bushing is going out. As for the R-12, couldn't tell ya, cause I riped all my a/c stuff out /forums/images/graemlins/thumb.gif
  2. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    more then likely the brass bushing inside the fan motor are worn,makes the arm wobble and the fan hit the shroud.if thats the case a new motor will fix it.also what happened on mine is the bushings were worn and the last owner still used the fan,craking the plastic.so i need both motor and new fans.dunno the price i never fixed it i dont like a/c.
    if you need to get it recharged also check the price to convert it from r-12 to 134 maybe cheaper in the long run.
    goodluck.
    p.s. there was a really good write up on here about how condensation effects rear a/c units,you might be interested in doing a search for it.
  3. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Mine made noise because it shifted in its holder and the cage was rubbing and making noise...convert to 134a...its cheaper and does a good job as 12 is $50 a pound.
    DW
  4. Thanks for the tips. I just got this Sub last Sunday, so I don't know much of its history. This is my 3rd Sub, but the only one to have functioning ac. I will have the system looked at to see the reason for the lack of cold air. I am in Oklahoma right now and its been over 100 almost every day.
    Mat
