rear axel ratio
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by acos, Nov 20, 2001.
  1. acos
    acos Newbie
    Nov 20, 2001
    I have a 1980 Blazer, and was curious what my rear end ratio is. I recently put in a fuel injected 305 and a 700r4. Probably gonna need a lower gear huh?
    thanks
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    2.73 or 3.08 SUCKS I have a 2.73 with 32" and never use OD
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    either pull the cover and count the teath or jack up one side of the rear if it is an open dif and turn the tire one complet turn and count how many times the driveline makes a complet turn so say it turns 3 and3/4 you would have 3:73's 4 and 1/4 4:11's and so on
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    I agree 3.08s suck! I had them on 35's and a 4spd tranny i could get up to a nice high speed in my "4th" gear. I like my 4.56 now but alot lower top spede
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    next...highflow cat, single inlet dual outlet flowmaster with 4" tips =D
  5. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    If it's a stock rear, then the RPO codes should tell you. You can locate the RPO codes either in the glove box, or on the drivers fender well inside the engine bay.
    If you can't find the RPO, or you don't think it's stock, then do the suggestions already given.
    You will not need to change gears because of an engine/tranni swap. Lower gears are usually for larger tires. What size tires and/or lift are you running?
    Thomas.
    On a side note, fill out your profile so we know what you are driving ..... 1980 blazer is a little vague........
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
  7. dyeager535
    26,982
    191
    Please for the love of god DON'T COUNT THE TEETH. I have nightmares of people pulling the cover off trying to count teeth, when the stupid ratio is stamped right on the outer edge of the ring gear, in front of your face.
    I could only hold off on that tirade for so long. Sorry.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  8. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    That wasn't very helpful. Would you care to explain why?
    A computer once beat me at chess, but it was no match for me at kick boxing.
    <a target="_blank" href=http://photos.yahoo.com/dana60manual>http://photos.yahoo.com/dana60manual</a>
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    **rolls eyes and thinks to self, here we go again**
    <font color=green> Too bad ignorance isn't painful </font color=green>
  10. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    ..and again...
    dents ....
    O R D's axles
    NO BREAKAGE :)
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
